[MOD] Remove Verizon Wireless***Updated 3/20 All Roms***
Re: [MOD] Removed VerizonWireless From Lock and Drop Down
Hm...I just flashed CM9 alpha (4.0.3) and it doesn't seem to work. I'm getting the boot looping problem:( Any ideas? It's not the end of the world...but I rather liked the "Google"
The framework in cm9 is different than stock. This will only work on stock. I posted a quick how to. Try it out and get it running for cm9.
Are you sure the permissions aren't supposed to be rw-r-r-- ?
I looked at mine, and those are the permissions of mine before I flash. It might help everyone who has had problems?
____________________
"King of the 'Self-Edit'"
"Patriotism is supporting your Country at all times. And your government only when it deserves it" --Mark Twain
Are you an Ameri-CAN? Or an Ameri-CAN'T?
That's how mine were set up. Its worth a shot as you laid it out. I would just click all the buttons. It can't hurt. Can't break this thing :)
Lol. True...unless I drop it and then complain that it's not built well enough, side-stepping the fault being mine.
Isn't it funny how when you put the word "The" and the word "IRS together, it spells "theirs? " Coincidence? I think not.
Just did this on my phone. Downloaded the file to pc then moved to phone. I didn't mess with the permissions just replaced the file. Happy to say that even after multiple reboots the change still sticks.
Side note, this is the first thing i've done to my phone since rooting it. Thanks for the work you did making this mod and the details on how to install it. Made it easy for a super noob like me to do!
Glad it went OK for you! Enjoy and thank you.
System/framework/framework-res.apk/Res/xml. You will want to pull the Eri.XML file. Using a xml editor (forgot what one I use) you will see the code on the left and the text break down on the right. Find the Verizon wireless line and overwrite it or space over all the text to erase it. Then drop the file back into the folder with 7zip and save it. Push the framework-res.apk file back to the phone or copy paste over the stock.
When you open the xml file in an editor, does it have a bunch of ASCII characters in it like this?
Just curious because it doesn't seem to be a text file.
It's been some time since I made some mods but I wanted to share this. It is for stock framework. It will remove VerizonWireless from your lock screen and your drop down. Install is simple. Download the file and and place on your phone. Using root explorer find the framework file and copy it. Then go into system/framework and paste. Before you paste make sure you are in R/W mode. Once you hit paste it will just reboot. Give it a moment and it will boot back up and it will look like in the photos.
No Verizon - MEGAUPLOAD - The leading online storage and file delivery service
Google - NOTICE
Galaxy Nexus - NOTICE
Stock - NOTICE
Click to view quoted image
MegaUpload is dead. Killed by FBI. RIP. Where else can I get the file do remove Verizon Wireless lockscreen? :-X
Thanks
Thanks
Yea I noticed. I dislike most other file sites. What's a good one that's not under attack right now and I'll move them.
Dang got here too late. I'll keep an eye out for new link. Good work tnt
Yeah, I'm late to the party as well. I'll be watching this thread in hopes you post them somewhere else. Thx
Any luck with hosting the file somewhere else?
I found this site, since I just got my nexus and I really want to tried this mod.
Suggestion to the OP, have you tried dropbox? It's legit, unlike most other file sharing sites online, and you can easily manage your files with a desktop app. All with a free account.
I think I'm going to make a how to. I'm on bugless beast now so would need stock again. With the how to no matter what rom or version on ics your on you can have this mod. Its simple to do.
Sent from my Xoom using Tapatalk
Think you could reup it now? Really wanted this. :D
Ok I found some time to rework this. It should now work on any rom. I'm just looking for a place to put the file up for download. New link will be up soon with a new how to.
Everything is updated and ready to go. You will find everything in the original post.
Hate to necro an old thread, but anyone know how to do this on current device stock rom running android 5.1.1.?
uOttawaGrad_22
