Jennifer Stough
Retired Moderator
- Feb 12, 2013
- 1,970
- 8
- 0
You can't do that! Leaving us hanging. Where did you find the Carbon ROM from and what kernel did you flash? I've been searching for a great ROM for my phone and I haven't decided on one that I like. Right now I'm trying PACman. I might ultimately end up using the Viper one, but I'm holding off since I don't want to settle considering there might be something awesome.
Thanks bud.
Btw...whatcha digest?
Don't know what sweep to wake is? Lol
Sent from my HTC6435LVW using AC Forums mobile app
Sweep to wake (as I understood it) is a way to unlock by swiping across the hardware keys. It did not work for me when I tried it.
Also, DanielLynch, I've had no bugs or issues crop up except one; yesterday my screen kept flickering blueish (I'm color blind so don't hold me to the color) like the dev setting to flash whenever there is a change. I rebooted the phone and it went away. No idea what caused it, hasn't done it since. Also using the new 4.3 camera, no problems there.
If you want sweep to wake, you'll have to run a kernel that supports it. The only one I think we have is beastmode. You'll have to flash it and then enable it in an app like trickster or system tuner.
Sent from my HTC6435LVW using Tapatalk 4 Beta
Im liking the illusion rom so far... I'm not a fan of the Halo since its buggy. Anyone have any "lag free" roms they like?
I had to get rid of the illusion rom, Web browsing was a headache. Everything was so laggy, but man was the key lime pie pretty. I went all the way back to Viper to take out the lag, I'll check out the super stock rom. It looks really good. Anything that you found not working?
Or is it virtually as simple as downloading the ROM zip file to the phone and then telling twrp (or cwm) to install that ROM from the zip?
-AJ
