Moving Apps to SD Card
For those with problems moving apps to the SD card, make sure you have your phone set for media storage on the SD card.
Go to Menu.
Then go to Storage.
Then look at the bottom and make sure you have SD Card chosen for media storage.
Not sure if that's your problem, but it's worth a look.
Sent from my Motorola Photon
using Tapatalk
Reactions: HollyDolly
Go to Menu.
Then go to Storage.
using Tapatalk
Yep, done that already. No change on being able to move apps to the SD card.
This is getting frustrating.
You can't move your apps to your SD card. I just found this out yesterday after buying a new phone(X2) and a 32 g SD card. I'm kinda pissed about it. Card is stuck at 29.66 can't add anything to it. Verizon guy said this had something to do with people stealing the apps via SD card. If this is the app developers fault well they won't have much to worry about because people just won't buy anymore apps. No way to store them! I upgrade in a year. I going to start looking for devices with either very large internal storage or the ability to move app to SD.
1. Tap 2. Scroll to and tap Files to open the file manager 3. Tap Internal phone storage 4. Scroll to the folder or file location to your desired file 5. Tap and hold the file,then choose Copy or Move 6. Press the back key and Tap the SD card 7. Scroll to the folder or file location where you want to place your desired file 8. Tap Paste here 9. Your file has been placed into your other storage location
Found this though. It worked! See if yours is the same.
Reactions: popologuy
As mentioned phone has dedicated app storage I have over 300apps and very little dent in storage
I believe the X2 has even more storage space
My original X had a insane like 8gb or so
Sent from my DROID BIONIC using Tapatalk
Wow.....that was easy. So it is possible to move apps to SD card without rooting. Way to easy....thanks moosc!!!! More in love with my MoPho.
Yeah moosc I found the fix (posted above) but your wrong about the X2 internal storage I only have as of right now :total space 4.30 available space 3.65(was 0.00 till I found this fix) thanks.
In step 1, what exactly is one supposed to tap? Does this fix really work?
Taylor Bag
