My first S24Ultra complaint...
Are you using gestures or the nav bar? if you're using the nav bar, you may not realise just how jarring it is to have this huge bar pop up just for voice typing and push your keyboard awkwardly up the screen. Awful UI design.
I'm using it how it came out of the box. It's extremely jarring to me too. No reason they can't let you choose to take that AI thing off and make it a voice mic icon.
For me, the only reason I'm using Samsung Keyboard is the AI feature. However, I agree that we should be able to add a voice input button to the toolbar.
A couple of days with the Samsung keyboard has really hammered home why I use Gboard, lol.
It's just not as good at predicting as Gboard, I used to love Samsung keyboard it actually had better options but Gboard works flawless for me.
Reactions: J Dubbs
Using gestures and the only way to use voice imput is having the mic down in the corner and pushing the keyboard was up. Irritating. Why do I have to have that just to have the option to hold the space bar also. Doesn't make sense
Reactions: fuzzylumpkin
It sounds like Samsung is pushing more and more people towards using Google and third party apps on their phones... pretty soon they're all going to look like Pixels running Nova launcher 😯😄😉
you might not be too far off with that comment. wouldn't bother me, too much. I'm accustomed to adjusting lol. fwiw, I use SwiftKey now exclusively.
Reactions: J Dubbs and pteezay
My new S24U's display looks almost like my wife's A23. And even worse in Comfort mode. Been playing around and adjusted the warmth to make it a little bit better.
I use the default Samsung keyboard, Gboard and SwiftKey. I'll just change it up every so often. The settings have always worked when I get new devices. All three keyboard apps work for me just fine, and I don't have a specific preference.
For the Smart Switch issue, make sure you've granted the necessary permissions during the setup process.
If you're required to press OK after typing your PIN, this could be a security feature. Check your device's security settings to see if there's an option to streamline this process.
Reactions: Laura Knotek
On the positive note, I noticed that you can uninstall or disable all unnecessary apps. I had to use adb on my S23, now it's not needed
Reactions: J Dubbs
I just switched to Gboard. Samsung keyboard was starting to annoy me with missed presses and bad predictions. Also hate that the exclamation mark is all the way on the left side rather than lower right like on Gboard. I guess I'm just used to Gboard working for me. Gboard messes up presses for me though too. Hoping I can resolve that or just move on to another keyboard.
Reactions: BEaRebel
andiox
