My hudl2 crashes when plugging in hdmi cable?
A
AC Question
I use my hudl2 to watch catch up etc on my TVs,worked fine now it crashes/freezes when I plug the cable in. I've had to do a factory reset to sort it out,but it still freezes when I try the cable again.once it is unplugged it the device works fine,often with a 'hdmi has stopped working' message
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,650
4,793
113
HDMI cables are pretty inexpensive, so that would still be my first step. Or maybe you could go to an electronics store and ask nicely if they have mini-to-standard HDMI cable (or whatever cable your Hudl needs) that you can test out on a monitor or TV there.
Tiigi
I am having exactly the same problem. It is definitely not the cable. It crashes and reboots itself, then locks the wifi off, it also doesn't make the reboot sound. I have to reboot it again to get the wifi to connect. Works fine without hdmi connected. Used to work properly but as soon as i connect the hdmi now it crashed. All apps have been updated.
Has anyone else had this problam and found a solution?
shirlysmith44
