Myn RLS 2 is out!
Just backed up my current VaelPak build, does this have a kernel built in? I can't live without the O/Cing!
dang it :( Oh well ill just flash kings.
I've been out of looking into the kernels, is anything new and good out yet? Kings 10 didnt work well for me and I had to flash back to 9
never really into trying kernals but im using the htc kernal with the battery hack they have been doing pretty great for me but i think ima switch kernals soon, wanna experience the rest
boobie, let me ask you; Is their a way to get the font to BOLD out a bit? It is kind of hard to read.
With VaelPak I had a font switcher app but I forgot it isn't in the market.
Thanks
EDIT: this Rom is pretty awesome even with the stock HTC kernel, might not even bother overclocking this one.
Thanks
yea just flash a diff font zip, on the first page igotan posted a page to the fonts, i flashed the first flash zip they have lovin how it looks
Decided to give Myn's rom another go. Round 3....FIGHT!
I am actually liking it this time around. The Launcher Pro theme is nice. UI is smooth and responsive.
Battery life is not that amazing. Just flashed King's CFS11. Maybe that will help. If it isnt good I will try King's BSF9.
Some times my home screen takes a few seconds to refresh itself and parts will appear blank until it happens. Not a huge deal.
Since this is a Sense rom the HTC calendar widget should work right? Anyone know where I can find this? Does not show up when I try to add a widget. Also not found in the Myn Folder on my SD card.
Thanks for any help.
If your using launcherpro the HTC widgets won't come up one thing I don't like about launcherpro but the theme is sweet
Sent from my PC36100 using Tapatalk
Oh thats right! I forgot.
Know of any free calendars similar to the HTC one? I like seeing an entire month. at a time.
Um not really I use calendar much. But if u search market there should be something lol
sent from my HTC Evo using tapatalk
Nothing like HTC's but for reference Simple Calender Widget is kind of cool.
can u tell me more about this battery hack you talked about?
what is it and where can i get it?
On all roms including being stock, I can't get mms over WiFi. Not a big deal really though.
Battery tweak is the same thing as using set CPU profiles, unless I'm missing something.
Been using stock kernel with set CPU, I get good batt life I suppose, gonna see what cfs 11 is all about now.
let us know how kings 11 works for you,
the battery tweak is way more then setcpus profile i think, if you look at it, you can set so many different things, #1162034 - Pastie
so far i got 62% battery left with heavy usage, with it being off the charger for 5hrs, doesnt seem so great but im going to leave it off the charger while i sleep and see how it drops, ill take it to work tomorrow and leave it unplugged to see how long i can get it to go, i guess the battery tweak does something to optimize the battery making it last longer the lower it gets..
ill report back for sure.
its running pretty nice with the stock kernel with the battery tweak, try it out.
you gotta download the tweak separately, then flash it like normal, then go into adb shell and set it at either 2 presets myn made, over clocked tweaked or normal tweaked, or u can set it the way u like it.
im currently using the overclocked preset.
You know the one myn was talking about a write up by myn is like on page 3 of this thread. He explains how it works and stuff
oh so you meant the battery tweak,
thats what im testing right now.
just woke up and its got 52% of battery left..
thats with 13hrs and 30mins since uplugged.
got a pic too just for reference.
I have the Battery tweet set to 1152 defaults...
I'll see how this turns out...
I'm running 1209 in quadrant
It seems smooth so far
Testing the Hot restart feature now... lets see how quick this really is...
Jerzy this is a baked in version of that thing we spoke about :)
and its done restarting... Very nice about 15 second reboot
Yes normal usage for me, light taking, heavy txting, moderate internet use, and moderate tapatalk use.
So far I am very pleased.
From my HTC EVO using Tapatalk pro.
Ltcharensey
