Myn RLS 2 is out!
Yea the hot restart is pretty cool feature.. and I have same settings.
And thsystem pretty good for having that much battery left I usually never get pass a day on any Rom
sent from my HTC Evo using tapatalk
Good to know... Maybe I can finally leave my USB Charger at home for once...
But I have an uhh ohhh 4G seems broken...
I did a Hard-Restart now to test... That will be a deal breaker for me if this Battery tweek jacked up my wimax
I'll have to restore Thank god for Nand
Update: Hard-Restart Worked...
Perfect timing reading bout the 4g as I read it I realized I was in a 4g area in queens but my 4g worka fine with the hack
I decided to flash netarchy beta 5 kernel and this thing is amazing. A few graphically glitches he and there, hard to describe, its not tearing though.
Gonna flash kings 11 now, the glitches are annoying when texting.
Thanks, will have to try it at another time, still gonna see how long I can keep her going on this same charge.
Hows everyone liking the rom?
Anyone else using stock kernel and battery tweak besides me And d3?
From my HTC EVO using Tapatalk pro.
Usually I don't like launcherpro but the flash on myn had rocks
I've never used it.
Is it just like a different UI set up?
What kernel are you guys using with Myn? Have you had time to compare more than one for bettery life? Right now I'm running stock kernel without the battery tweak. No SetCPU either, I just want to get a feel for this battery life before I start switching around. Thanks.
It's just the bottom look cooler to me I like it how look..
and using stock kernal
I flashed the ROM and it is indeed very pretty (I like the new boot animation). Unfortunately, I have the problem with the android market so I went back a nandroid backup. I'll have to try the fix posted on page 4 when I have a free second tonight.
Fix for those who have the problem and don't want to dig. Thank Richard_Danger if it works:
"I had the same issue with ROM's prior to Myn's and with RLS1. What I did to get it to work was Force close the market, clear the data in the market. Go sign into Google Talk. If it doesn't sign in, give it a few tries or just turn your screen off and wait 5 minutes (both have worked). After you sign in, your downloads will start back up. But since last saturday, I havent had the issue again."
Yea the Rom is great but news the market just make sure u clear cache also
I had only the issue of my SD card saying not mounted after a reboot it fixed
jipeve
