Need help
quick questions, did you try the kernel from the link I posted from the support tab? or the kernel tab?
Yes I tried all the ones you posted or suggested. The stock one froze at the first boot screen. All the other kernels would just boot loop.
I have no problem with that but I downloaded the unroot file in the link you posted but when I choose it in clockwork recovery from my SD card nothing happens.
not from clockwork, if you put that pb zip file on the root of your sd card it should automatically ask if you want to update from hboot menu (vol up) for yes..is your sd card farmatted to fat32
No clue, DO I format from windows or the phone itself?
windows, it probably already is, on xp if you have the file highlighted it should say fat32 somewhere in the left column
Also, will I lose my contact numbers as well? If I do no big deal, just curious.
maybe but if you had verizon tranfers your contacts from an old phone there is likely a cv file on your sd...well cross that bridge when we get to it
no im dumbfounded...the phone automatically tries to upload ay pb31 zip no matter what. what are you seein when you reboot?
Taylor Bag
