New Android Market V2.2.11
Be careful if you chose to flash the .zip option. The ROM that im trying to install the market on is a gingerbread ROM and doing the flash did install the market, however the app does not run. Flashing it embeds the app into the OS as a rremovable app and I now have to reflash the ROM completely.
How would I get this market update on my nexus 1?
Yes, installed on my N1 just fine. Just DL the apk file to your computer, connect your N1 to your computer via USB, and drag the file to the download folder of your N1 (sdcard/download). Disconnect USB when done.
To install, use astro file manager to locate the apk file, and click on Open App Manager, then install.
You could just download it with your phone. You wont have to be on a mission
Reactions: Membrillo
new market
I am new to all this, and trying to install vending 2.2.11, I want to learn, do i download it to my phone or on my pc, and do i need a zip program on my android, thanks in advance
I just downloaded the apk file to my grab and it installed w/ no problems. Thanks for the info and posting this for us all.
How do I uninstall this version if I want the older one?
Which way did you download it? If you flashed the zip in recovery, did you do a nandroid backup before installing the new market? If so you can just restore that backup.
That would be the easiest way
Hey.. How do I unzip the file on a MAC???? So i can install it..>>>>tks;)
The zip needs to be flashed in recovery
Please help! I downloaded the zip file and installed it from the recovery mode. It said successfully installed, so I rebooted my phone. When it started back up I could not find it. The place where my old market was on my homescreen looked different. It looked like a piece it paper behind a gear. When I clicked on it it said that was no longer on phone! So I lost my old market and did not gain the new one! What did I do wrong?! Please help!!! BTW I have a rooted HTC Hero CDMA running 2.1 and I have Fresh Hero 2.4.0!
I have NO market now please help! See my above post!
So you are still running Eclair on your Hero? Maybe someone else can confirm or refute this, but I was under the impression that the new market was only for Froyo and GB? If that is the case, then that may be your problem.
Do you have the vending.apk on your device?
For the Mac install StuffIt expander. The free version and just double click on the file and StuffIt will do the rest.
Reactions: ironkittenn
Help for the not yet so techie types
Sorry but can you give a step by step how to instruction? I have version 2.2.7 on my Incredible so how do I get the 2.2.11 version onto my phone??? :eek: Sorry to be lame but I really need a step by step for this one. All help is greatly appreciated.
Assuming you are not rooted, download the apk from the OP and put on your sd card then use ASTRO or ES File Explorer to open the apk and install in app manager.
I DO NOT suggest flashing this zip or installing this .apk on EVO. My market is now borked bad. I am getting FC's with every version of market. I've tried everything including fully wiping and re-flashing ROM + gapps (CM 6.1.2). I've tried going to settings/manage applications and clearing data + cache. I've tried removing and reinstalling the vending.apk via root explorer.....and I've tried wiping cache/dalvik via recovery.
Did you do a nandroid prior to installing the new market? This was happening to me in an older version of a black market and realized that I had to vending.apk files on my device, and believe that is what was causing the constant FC's. There was one that was "Vending.apk and "vending.apk" I forgot which one was bad and that had to be deleted but ever since I have not had a problem flashing a new market or themed market.
I accidently deleted my CM nand backup. I do however have a sense ROM backup still. I'm going to poke around with root explorer a little more and if that doesn't work, I'll just restore the sense ROM and then reflash CM6.1.2 and start all over from scratch....grrrrr! This is seriously pissing me off. 4 hours of my day down the toilet.
That sucks man, Im sorry. I know how you feel, its pretty frustrating and annoying.
Just wondering why everyone wants to install this version of Market? Is there some major bug fix or new features?? This version just got pushed automatically to my phone this morning... it updated itself. I am not sure why though. There were no explanations or anything... it was just automatic (and I do not even have automatic updates checked). That was sort of disturbing because I always like to know why an app is updated before I install it (changelog). And I'd especially question why it is automatically updating itself. It seemed sort of sneaky, in fact, if I had not been watching, I would not have even noticed it download/install itself. Anyone else have this happen?
Prior to this post it had already began to be pushed out to devices and this was for those that wanted to load manually and not wait. According to Upstreammiami it fixes security issues and assuming other small bugs. The market always gets pushed and updated automatically, unless of course you do it manually which will prevent the auto update from getting pushed, because you would have the most current version of course.
kalikama1
