New Android Market V2.2.11
pushed?
I guess since I don't know how to be a root user I will wait. Anyone know when its going to be pushed out?
Thanks,
Works fine on my EVO runing Fresh!
Installed the apk, reboot and voila!
MM
You can start by clicking on the "Rooting" tab above to learn more. If you want the new market and it hasnt been pushed to your device yet then you can just download the apk to to PC then put it on the root of your sd card and install it using either ASTRO or any other file explorer.
I installed this and lost the ability to show my installed application. It would only show 3 applications I installed which was done with this version. When I removed the update it showed all my installed applications. I have a Droid X.
When this happens all you have to do is go into
Setting>Applications>Manage Applications>Market>Clear Cache & Clear Data
After that reload Market>My Apps and everything should be in there
Hi everyone i had a question i just rooted my fascinate so what can i do with it ? can you help me out ? i would like to make it run better and maybe change the theme on it please help me out thanks
Have this one Android market 2.2.6 if anyone wants to explain how to upload from my EVO cuz home pc is down !
Are you rooted? If so just download the zip on your device and move it to your sd card with ASTRO or whatever file explorer you use then flash the new market in recovery.
If you are not rooted then download the apk and use ASTRO or the file explorer you use to install the new market apk
Thanks for this info. Going to reboot the phone into recovery, perform a NANDROID backup and flash the zip file :)
koltyn
