New MR 2.5 Radio Leak
Will this work w/ latest Flyweight and MR2? Also, does this require or initiate a wipe?
Thanks!
Been running the radio all day and nothing to report. Phone works and haven't had a random reboot so far. Will see how it goes over the weekend.
Reactions: ssethv
Well I was good on the radio till about an hour ago I had a reboot. Decided to go back to MR2 since it was working quite fine.
Sent from Tapatalk using my das BAMF REMIX'd ThunderBolt.
I'm getting a constant 11 mbs down now, when before I would get anywhere from 18-26 mbs down.
Anyone else seeing poorer battery life with the MR2.5 radio compared to MR2? I'm seeing a much higher drain on the phone overnight.
Not sure. I just went 14 full to dead. Used the phone a lot today, mostly wifi. Not sure where that stacks up for me.
No reboots yet.
Sent from the Bolt via Tapatalk
No reboots here yet. Seems to be working fine. Battery life seems the same to me as the other radio, but then again finding the right kernel can fix poor battery life.
Reactions: ssethv
Had my first random reboot since flashing the MR2.5 radio. Was in the middle of writing a post to the forums here when my phone rebooted. For some reason, I've had really bad standby battery drain since I moved to the MR2.5, but I'm going to wipe battery stats and see how things go over the next couple of days.
Edit: Just had another random reboot.
Reactions: zero neck
Noooooooooo... I feel lucky.
I just put in a new battery about 30 min ago at 17%. That's 17% from last night (my last post). Light usage all day. That's 21 hours on a cheap $12 for 3 1500mah batt. I didn't even know what was possible for me, even on light use. I don't really pay much attention to my battery usage because it's so sporadic in use and results.
Still no reboots. :confused:
Edit - That sucks.
I'm using the Planejane V3 based on the MR2.0 radio/baseband had have had several reboots over the last couple of days. I'm hoping this works or it's back to original rooted 1.12.605.6
I've been running MR2.5 all weekend.
No reboots, improved battery life. Definitely better connectivity in the greater Cleveland area.
I was running the Flyweight ROM with MR2 radio and never had any reboots. I wiped phone and installed the MR2.5 radio, then several hours later got a reboot and bad power drain. I rebooted, wiped again, and battery stats. A couple hours later got another reboot. All this was on 3G only, no 4G where I live.
I reinstalled MR2 and Flyweight and have been up for 40 hours, no problems and normal battery life.
It seems like MR2.5 does not like my phone.
2.5 for about 2 or 3 days now, had my first reboot overnight last night while on the charger.
Otherwise it's seemed to be pretty good. If i get more reboots i might go back to mr2 and see how that goes.
Edit - That sucks.
also totally agree with this about tbolt battery life. it's all over the place.
what kernel have you been using with it? that could effect some of this stuff
I have an unrooted phone, and installed the MR2 leak. Can I install the 2.5 radio leak and keep all my data, or will it wipe the phone again? Also, I noticed 2.5 radio is only 25 mb so this is just the radio correct?
cany
