New Radio Leak...Gingerbread RUU THANKS CHINGY
just click the link that says Ads or Mirror with ads and that should take you to the download
I did not need to register. Did not notice any 'ground breaking' yet, but will see how the day and evening progresses.
Can this be installed on a stock tb? Thanks.
Sent from my ADR6400L using Tapatalk
doubtful since I don't think it's signed. You'd need to be on the rooted MR2 build.
It says in the title it is a Gingerbread Radio.... so I'd agree it is doubtful it will work on a stock TB rom.
It uses the same RIL so it'd work on MR2 but you'd need s-off to flash it since it isn't signed.
Man, GPS and location were perfect this morning, now my location is all out of wack for weather and seek droid (was good this morning) on both, but g-maps still has me right. Anyone know how to fix this?
Hey, question, I have CM7 on my phone right now from the MR2.5 build.
Can i still use this radio? or would i have to flash the MR2 radio version of CM7?
Take your phone outside, place on ground, and smash with baseball bat.... JK....;p I wish I could give you an answer bro..
AND i also am waiting for at least two weeks to see how this "new" radio will work out for people... I am using the .627 radio and see no reason to upgrade since everything works perfect for me :)
It says in the title gingerbread or froyo based roms. No matter, ill wait for the full RUU.
lol, it just started working again. Just a little hiccup I guess.
Yes, froyo based roms that are made to use the MR2+ radios. Not the stock one though.
I changed the file name to .zip and when I get to the hboot it doesn't automatically start downloading it like the previous radios is it something im doing wrong?
You changed it to what? It need to be to PG05IMG.zip and on the root of your SD card.
Running BAMF3.0 rc4.9, just flashed this raido. Getting instant 4g and instant GPS lock. GPS lock took 10 seconds using the official MR2 radio.
running same combo, and I love it. Ill post later tonight on battery life. I have the HTC extended battery and I average 60-70% usage with constant 4G audio streaming.
thats exactly what is when i check both on my computer and the astro file manager
How are you trying to run it (there are different methods)? Make sure it's in the root of your sd card. Power off then hold vol down and power button until it boots. It should take. Maybe try downloading it again and checking that the MD5 sum matches.
Just trying to help man, not saying you don't know or haven't tried these things. :)
What does it say on the screen after you get into hboot? Try hitting Fastboot if that's an option.
Tfunz
