- Oct 18, 2016
- 57
- 0
- 0
Yes, that's it.
Cram a 4000 mah battery into the space for (factory) battery? Ah huh, Note 7 all over again?
Is that the Titan Grey unit? If so is it darker than the G5?
Since you mentioned DAC, how does it compare to axon 7's DAC?! (if you tested it)
You can't be serious. Not with that dusty *** lcd screen.
Hrm, the screen on the N7 does seem a lot brighter.
My V20 was brighter than the Note 7 I use to own.Hrm, the screen on the N7 does seem a lot brighter.
The S7 edge and Note 7 viewing angles are a little better but nowhere near blowing the V20 out of the water. I actually like the V20 screen better!!.. Doesn't look all cartoon like and over saturated. The Note 7 and Edge screen are also a lot warmer than the V20 when compared side by side.The note 7 was the brightest screen on any phone. Comparing the v20 to my s7 edge in the store, the edge was maybe a little brighter when they were both at max, but with both at 75% the s7e was clearly brighter. LG screens seem to only get really bright above 85% or so.
Viewing angles on the s7e also blow the v20 screen out of the water, but I expected that. All in all, I've accepted the fact that I'm downgrading in the screen dept to regain a replaceable battery, a bigger (flat) screen and an ir blaster. I'm surprised how much I've actually missed the ir blaster lol.
I hope they make wireless recharge backs for the phone
