Tall Mike 2145
- Feb 8, 2013
- 411
- 0
- 0
Read post #8 here:
Broken Screen Replacement
It's a design flaw. Nexus 4 has thinner glass than any other phone on the market (including Nexus 4 Optimus). I've already replaced the front screen, and, to add insult to injury, the back cover just went - all within a month and a half of purchase. This is really poor build quality. My old Galaxy S lasted 3+ years and continued to work fine even after I managed to crack the screen (two+ years into its life).
I have found the same thing and will be going back to the Iphone . i dropped my iphone off a semi truck(about 14 feet) and it still worked even tho the screen was cracked these nexus phones are crap. I called lg they told me to call another place and they were rude and i am very unsatisfied with the customer service. When i bought the phone they told me it had the strongest glass of all phones they lied so now it will cost me over 1000$ to pay for this crap phone and buy a new iPhone all i can say is wow.
Lol, your iPhone will break from a 2 foot drop.
Sent from my pure Google Nexus 4 using Android Central Forums
Well, I guess I will be yet another "1 post wonder" that believes there is some form of a design flaw in the N4's glass.
I have had mine now for about 2 months, and I have treated this phone like a newborn baby. I have always had second hand, or second rate phones. I finally decided after playing around with a friends N4 that the time had come to finally treat myself to a quality phone.
Since the day it came out of the box, it has had front and rear, quality (spigen ultra-clear front, and xtremeguard back) protectors on it, as well as being in a Body Glove case. The phone has never been dropped, never been sat on, and has always been carried in a belt case, so never even been pocketed.
Tonight, I decided to remove it from the Body Glove case, just to give it a good wipe down, and guess what? Back glass is busted all around the speaker, and cracks have started to extend from that point, and have reached almost to the camera.
Honestly, I am at a loss. People actually make fun of me for the way I treat this phone. I carry a Muck-off microfiber cloth with me, and wipe it down practically after every use. To put it lightly, I am downright OCD about the way I handle it.
I have searched, and I am not alone in this type of break. I am not crying foul here (although crying might make me feel better at this point), but I do believe there is an issue with the back glass, especially around the speaker. From what I have read, the newer N4's have had the back glass redesigned with some "nubs" to help with breakage. It would be really nice if LG would offer a replacement, especially if it is obvious that the phone wasn't dropped or crushed. I am going to try, but I am not keeping my fingers crossed.
I also don't buy that it was never dropped or force was never applied to it. Glass doesn't just break. Something was done to it (whether intentionally or not) that caused it.Sorry for your loss, but it's a defective unit. Not design flaw.
I've read plenty of stories of people dropping their N4 from waist level and having nothing break. You just had some bad luck and it has nothing to do with Google or LG. If you want to go back to apple over this, do it. Buy I doubt that apple would replace your broken screen either.
Guys, this is a true story:
Yesterday my son dropped a porcelain plate onto our Granite floor.... Kabooom... not a single chip on the plate despite a hight of 3 foot or so. My wife dropped a similar plate onto our glass table and... Kaboom... the plate shattered from a hight of about 15cm.
Moral of the story is you may drop things and it may not crack.... you may drop things and it may crack. Best not to drop things.
I have to agree. I've been trying to be very careful with my N4 because of the 2 glass surfaces. I found my iPhone to be decently drop proof. I don't use protectors.Sorry for your loss, but it's a defective unit. Not design flaw.
I dropped mine onto concrete from about three feet. I shattered the back by each bottom corner on the back. The front held up. Found a store that replaces the back for $85. The new back should be in sometime this week. You can also get them on eBay. Replacing it looks quite easy provided you have the proper torque screwdriver set.
The back is insanely easy to replace. All you need is a torx screw driver and a plastic spudger tool to undo the clips.
Just make sure they replace all of the antennas on the back. If you want NFC you'll need them.
