Weird... My glass was slightly raised on the left side as well. I opened my cover up using a plastic grapefruit spoon thingy. All the screws were tight already. Put the battery cover back on and the glass on the left side of the screen is no longer raised.
Easy peasy!![]()
I got mine from Sam's Club too and the glass is raised slightly above the bezel. It has that spongy feeling. I've got another on the way from the Play Store. If this fix doesn't work permanently, I've got to take it back. XDA is saying the issue returns after a few hours.
This was my experience.
Could this issue get worse over time? If so i may try this fix. I hear its easy and my dad could probably do this in less than 5 minutes if i ask him too. If its not a big deal then meh. Mine isnt even 1mm out. and i only notice if i press which i keep hearing about so i do it.
It's got to be an issue with the back cover fitting too tight, which some people on XDA speculate could be the problem
If it's as tight as the box it came in, it's to tight.
Does make some sense though, mine was fixed after just taking the back cover off and putting it back on.
