Nexus 7 Installed in Truck - How to get back-up camera?
why not just pull up the browser and leave it up, and minimize when done?
Mine is often tethered to my mobile phone. Perhaps an app that would auto-launch tether when near the vehicle? I know if I leave tether on on my phone it will auto connect but I really don't want to do all that (and run up my tether data).
I was just curious how/where one might mount the camera inconspicuously(hidden)? Which camera model to use? Guess a regular webcam would work, right? Power for the camera??? USB with extra long cable to the cigarette lighter jack???
IDEAS???
https://drive.google.com/file/d/0B9SzP3j5MIl5S0dHSm1CZGhWLXM/edit?usp=sharing
I am looking for a similar solution. Cost is my major concern. I can purchase a stereo with a 6" display, and back-up camera ready. But to get the backup camera installed will cost around $200.
So, I see WiFi back-up cameras going for under $50. And if I limit the choices to something that looks a little higher quality, I find one for $130 at RVS-020813 | WiFi Backup Camera System
I have a SUV, and ideally I would like to install it inside the car, at the top of the rear window. But, I have not idea if that will be workable. Reflections in the glass may be a problem.
My major concern is the time involved with getting the application to display the image. For example, I get in the car, and turn it on,. Then, I start the phone app. How long will I need to wait for the the image to show up?
Thanks for any advice.
-Joe
So, I see WiFi back-up cameras going for under $50. And if I limit the choices to something that looks a little higher quality, I find one for $130 at {I can't post your link}
-Joe
I have found generic rear view cameras on Amazon and eBay for as little as $5 - $25 which all show nearly identical specifications only varying in form/mounting method, focal length/degree of view (110° - 180°), listed Water Resistance Rating (IP66- IP69).
Also, Wi-Fi transmitters (which are made to connect to these cameras) for as little as $6 - $40.
These create a Wi-Fi network which you then connect your phone or tablet to, open any one of the many IP camera apps and you're golden.
Depending on how you want the camera to function you can wire it up to begin transmitting when the vehicle is shifted into reverse [wire the transmitter to the reverse lights] or have it transmitting constantly [wire to the running lights] which might result in faster initialization times.
I will admit I have seen cameras and Wi-Fi transmitter setups listed at much higher prices but not listing any better specifications. 4ucam wants $130 for the same things you can find for less than $50.
Just came across your site as I was downloading a manual for the RVS-020813 backup camera and I just finished the installation. Camera works great, I wired the camera to constant ignition so whenever i goto the GoVue app, the camera image instantly appears on my Note3 with no delay. Hope my input helps.
Thanks for the update. It is good to hear that it is a viable solution.
I ended up going with the direct-wire solution. That way I was certain to get a picture right away. My installer was also quite leery about the idea of using WiFi, saying they often are unreliable. My Bluetooth audio interface is certainly a testimony to why Bluetooth would not be a viable way to connect a backup camera. It is not unusual for the car stereo to take half a minute to connect to my phone. I would not want that long of a delay in a backup camera system.
-Joe
Joe,
Can you elaborate on your direct wire solution as this is what I would also prefer to do.
Thanks,
Charles
I purchased a new stereo with a display, that had the option to plug-in a back-up camera. I don't actually know the model of the camera. I had an installer do it all for me. He drilled a hole near the license-plate where he installed the camera.
Many stereos, that have large LCD displays, can accept the Backup camera signal, and can sense when you are in reverse ( it ties into the back-up light to know when you are in reverse). My Panasonic radio was certainly a challenge to figure out the settings to get the camera to work. So, I don't know if I can recommend the radio I purchased. The Panasonic radios are known for their obtuse user interface.
-Joe
Hi, quick question... did you use the easy cap to connect the camera and the tablet? Did you plug it into a usb hub?
Thanks for your help.
Good question. How does the OP plan to tell the Nexus the vehicle is in reverse? Can't use the accelerometer because you should look before you start backing up.
This is a "little" late but just have the app/Bluetooth connection to the camera start upon charging (automated process/scripted) which happens when the vehicle is started.
Flykxd133
