Nexus 7: Screen Shots
Re: Screen Shots
@EnDroidable which Wallpaper is that? Whats the name? C'mon folks, LIST the names of your wallpapers and any widgets or customization themes you use so people can use them as well to enjoy. Thanks. ANDROID 4 Life.
Re: Screen Shots
What widget are you using to display the day of the weeks like that?
I'm not sure if you received a reply yet but, If I am correct, he is getting his days of th week via a widget called UCCW. Which you can create your owne personal widget. Take a little bit of time but once you get the hang of it, you can make some awesom looking widgets!
Re: Screen Shots
Yes it is actually. And I like that if you're right handed and holding the tablet with your left hand, you can set the screen side to the right. Handy.
Re: Screen Shots
Re: Screen Shots
Finally found a cool Tron font to use with DIGI Clock. The live wallpaper is Digital Hive.
Re: Screen Shots
Looks even better with the live animation!
Sent from my DROID RAZR using Android Central Forums
Re: Screen Shots
Playing around with some themes for Nova Launcher and that UCCW thingy as you can see here.
[url]http://farm9.staticflickr.com/8369/8527121189_fce11cf1d6_b.jpg[/url]
Screenshot_2013-03-04-07-56-59 by ctt1wbw, on Flickr
are your icons from nova launcher or from an icon set? I see the screenshot from WordPainter is also using them. I like the shape of them!
I've had my tablet less than a week and still getting used to it, havent gotten as far as customizing with launchers and such just yet :)
Re: Screen Shots
I downloaded a separate icon them for the Nova Launcher. Here's a link to the theme. You can select the theme from inside Nova Launcher's settings.
https://forums.androidcentral.com/e...com.czarnomorski.theme.dcikonz&token=X_RXi48q
Re: Screen Shots
From my unlocked, rooted, stock 4.2.2 nexus 7. Shadow galaxy live wallpaper, nova prime launcher. A few odexed mods I built to flash in, like the percentage battery and tablet UI.
Re: Screen Shots
My first so far
Re: Screen Shots
The dev, Cypher Cove, makes a bunch of nice live wallpapers, so check them out too!
Thanks I will, can you just search by dev's? I'm gonna go check
Just checked, and it seems I already had 3 of their WP's installed and I just installed 2 more....so Gracias!:cool:
johnethan763
