I'm not too worried about being off topic, the main thread died a bit back.
There are two problems with your plan Tdm.
The first is, can your board support 8gigs. Some boards, especially older ones, say they can, but downclock the memory or fail to boot unless it is very specific memory. The second part is what Jerry said, DDR2 is very expensive right now.
Currently:
Newegg wants $129 minimum for 2 sticks of 4gb DDR2.
For $34 you can get 2sticks of 4gb ddr3, and a board to support it (up to 16gb) for about $50.
So you have a choice, $129 for memory, or $85 for an upgrade which leaves you in a better spot to upgrade later. Even if you only buy a single stick of memory, it's STILL equal or cheaper to change the board to DDR3. 4gigs is enough, but my advice, spend the extra money and get 8gigs.
This was my reason for the whole upgrade on mine. 16gigs (4 sticks of 4gigs each) would have run me $300. My board could handle it, but my SSD was already running at half speed. Worse still, no one makes a good DDR3 board with 4 slots that fits an older Core2Quad. $300 will buy an I5 and 16 gigs of memory, another $100 would get me a board. It simply didn't make sense. I hmmm'd and haww'd over it for a few months and then finally went for it when I found out my SSD was running at half speed.
Keep in mind, 4 gigs is plenty, even for games. Pretty much only artists and professionals will
need more, however, the extra breathing room is nice. 16gigs, is like using a firehose to water your yard, it's overkill, but it's fun and get's it done very fast.
In a similar vein to what Jerry said,
Hard drives are in a similar boat, flooding in Thailand has damaged the industry and prices have more than doubled in some case. On the plus side, I saw a 120GB SSD on sale for $130 yesterday. By the end of the year SSD will almost be standard on most notebooks and many desktops.
Edit:
That cooler will not handle your processor. That processor is 95 watts, the cooler is made for 65 watt cpus.
This on the other hand is a little beast of a cooler if it will fit your case, and it will fit a wide range of processors.
https://forums.androidcentral.com/e....aspx%3FItem%3DN82E16835103065&token=ZEf8iXwf
