NOTE 20 Unlocked How To Get RCS And Carrier Features
Since 3.1 update on my unlocked 20 on t-mobile I haven't been able to get samsung rcs working. Google messages just sticks at trying to verify which I'm not worried about because most of my peeps are on Tmobile and have samsung phones. Has anyone been able to get it to work on Samsung 3.1? I see on Xda some people are in the same boat after the update.
Try this , I have my att sim so haven't tested on Tmobile but will maybe over weekend, download alliance shield in play store >open the app>tap app manager>search ims settings >activity tap >first section tap and change those to how the xda thread mention , this way is to get into ims as Google dialer code doesn't work Screenshot_20210319-205143_IMS%20Settings.jpg
Try this , I have my att sim so haven't tested on Tmobile but will maybe over weekend, download alliance shield in play store >open the app>tap app manager>search ims settings >activity tap >first section tap and change those to how the xda thread mention , this way is to get into ims as Google dialer code doesn't work View attachment 332858
Sorry Mustang I should've clarified.....I was using the Alliance method but since the 3.1 update even after going back in and turning everything back on still no dice
Ok no problem, I'll test it with my Tmobile sim , I tried with att it didn't work. As you can see in my screen shot I get the advanced chat ,read receipt but when I try at moment with Att it doesn't work
Man I wish they'd get this together lol
Doing the alliance method I can't get the rcs chat thing but the green dot that used to be on the contacts is gone and there's nor read or delivered. I'm wondering if this 3.1 messed something up.
It could be 3.1 but through alliance I get the chat like in my screen shot
Man I need to proof read my stuff when in my phone. Lol. I meant I can get the chat feature options to show up but the green dot that was next to the person's name and the read/delivered next to the message is now gone. Periodically messages will just hand and then not deliver the message also. I was thinking about trying the U firmware and see if it works but Sammobile didn't have the Tmobile version of N986U1UES2DUC1 they had the Feb version. They did have the March version U1 Tmobile N986U1UES2DUC1
You want go to carrier version you can from unlocked but it will factory reset and you need frija to download the firmware and odin patched(prince comsey)
Unlocked with Tmobile , you get Wi-Fi calling, reception is very good , do the RSC trick and you'll have that in stock Samsung message app .
Between those 2 devices the Note I would choose, I stop buying the S series since s10+ , nothing wrong with them just perfect the Note line. But yeah don't worry for Tmobile on unlocked models works very good .
What's the RCS trick for the t-mobile sim in sprint phones?
angelag5098
