Samsung Messages with RCS
You can now , in the past you couldn't except Sprint at the time .
as I said in a different place, my Samsung Messages shows RCS toggled on in Settings when Google is selected as Default. once I select Samsung as the Default, RCS disappears for me, at least on AT&T.
Reactions: mustang7757
So this may or may not apply anymore: See if there is an Uninstall Updates under the top right three dots in App Info. Downgrade. Let Galaxy Store re-update it.
Otherwise ODIN and if that doesn't work, the backup might be no good. Re-export everything with 3rd party tools and set it up from scratch one app at a time starting with messages.
Out of ideas, especially above about carrier services which was a good suggestion.
There is no Uninstall Updates for my Samsung Messages. It's there for Google Messages.
Honestly, I don't have time to back everything up again, and then go through the whole process again. I can't deal without RCS on Samsung Messages. I just wish the orange dot notification would go away. It keeps showing me I can have RCS, but it always fails to register.
Clear data then force stop and see if it shows up
This is my s25u unlocked T-Mobile
What is going on over there?! First they want to kill S-Messages. Then they don't. And now Unlocked supports RCS?
This further cements my Samsung is becoming Google (no vision/direction). I digress.
My phone doesn't even have it installed anywhere. Not sure if I Shizuku'd it away or what. So this may or may not apply anymore: See if there is an Uninstall Updates under the top right three dots in App Info. Downgrade. Let Galaxy Store re-update it.
Carrier service didn't do anything for the Samsung message app , I tried that back in the day trying to get RCS with Samsung messages on unlocked, yes I agree it gets confusing now what Samsung is doing.
I can't be
But I just did the clear data and Force stop and my messages repopulate now I don't have custom ringtones or anything
I'll think about it. If after clearing data I lose my categories, I'm very far out of luck (unless I can do a restore from Samsung Cloud and the categories are saved there).
Categories won't restore. That's an app data thing. I just went through all of this. It will only give you your message back in one file dump.
I also tried this from the SmartSwitch backup I made but that too didn't get recognized and so im just grateful I have my messages at the least. I can reconfigure the categories, ringtones, and wallpapers over time.
and now I'll stop thinking about it 👍🏻😂
Reactions: Serkle K
wobblefix
