Notification LED on S10?
I only want notch notification for text messages too and see notification until I view the message, also keep my Lock/AOD/Home screen to stay the same as it is normally.
I'm pretty sure this will come - from someone, in the not too distant future. Obviously the capability is there, as well as the API's. Either Samsung will add it, or a third party. The way this developer is doing it might be a little clunky, but they have proven the concept. For instance, I use Light Manager for more granular control of my Note 9 LED. I could easily see them adding support for this. In fact, if it's not being done by the time the Note 10 comes around, I'll be sending them my requests! :-)
could you post more screen shots of more settings you have?
all i want is ring light to light for missed txt messages and i having issues getting this app set up for this. or you tube step by step video?
thanks
jeff
Here are shots of every one of my settings. I hope they help. Note that you have to click on "select enabled apps to set color and time" to select your messaging app and assign a color and flash time to it.
So, yeah, I just picked up the s10 and trying to get this app to work with gmail. It works fine for texts but it doesn't at all for gmail, for some reason. I'm not sure if everyone had to do this, but I DID have to choose "show system apps" to even see the gmail app. I'm not sure if that's because it came pre-installed?
Also, if I read correctly, there's no way to get it to work with missed calls? I selected "phone," also under system apps, and added it but yeah, nothing.
Fixed
Now if I can just figure out if this app rotates through colors when multiple apps have notifications.
Also, I saw someone mention that they couldn't get it to work with missed calls. If that's still the case, lmk, I've got mine working.
Fixed
So were you able to set it up to when the led indicator keeps on flashing every few seconds constantly as a reminder for you to check your notification that's been received? Without the screen lock flashing up as well? I just want it to function just like how the previous galaxy versions functioned...
so, when I get a text, email, missed call, etc, the way I have it set up is that the edges light up and the clock comes on, against a black background (not the lock screen) when I get a notification. But I also have it set to not stop flashing. So it will flash and show the clock until I double tap the screen (which usually isn't much long after).
I would like a missed call notice but there are 4 things listed as "phone" and I can't figure out if there is a way to know which is a missed call. Can someone point me in the right direction?
There were 5 on mine. It ended up being #4 for me. But just assign a color for each one and then test it with another phone. Which ever color lights up is the right one.
Could anyone put out a video on this?I have downloaded and paid for this app. I keep playing with it and run into a lot of confusing situations. The screenshots help, but a step by step explanation would be great.
Is AOD always on, especially when you have your phone in your pocket? I'd be worried about the battery life..
Has anyone had notification issues after the last update or 2? I started having the issue where, after I get say a text notification, I'll clear the notification, read the text/email, turn off the screen. But then I'll get the same notification for the next 5 minutes or so, mb another 4-6 more notifications even though nothing is in the notification bar.
It just started happening recently.
There's a LED case available, too. Haven't seen it in action, but it looked like a starry pattern to me? Might be a 'suitable' alternative for those who can't seem to accept an on-screen indicator VS an LED.
I accept it, but only because I don't have a choice. Does the led case show it on the front or back of the case?
I was one of those that really missed the LED notification, but I'm actually digging this screen notification I think a bit more. Mostly because it works with everything I used for the LED notification and it's full screen, so I don't have to look for one corner of the phone, I can see it from any angle.
Loki Samhain
