notification toggle grayed out
yes, if you enable system apps in Notifications > App notifications, the Calendar and Reminder apps appear in the list. Doesn't get rid of the greyed out toggle.
Not sure why those 2 apps are system apps.
I just checked the bride's S22U. Her Calendar app has notifications blocked. I'm wondering if, because they were blocked on her phone prior to 13, the setting carried forward?
Aha, so I enabled system apps in notification settings. Now the Calendar & Reminder apps show up in the list but with no toggle. I don't even get a greyed out toggle.Screenshot_20221208_154542_Settings.jpg
Sent from my SM-S908U using AC Forums mobile app
Thanks, I forgot about the system apps toggle. Now they show up, toggles still grayed out.
pro tip: if you restore your device from Smart Switch absent the settings, you will remember a couple of days later to turn off your RAM Plus so the phone will function smoothly.
Apologies if this is the wrong section of the forums.
I noticed on my S22U that the option to block/disallow notifications on the native Reminder and Calendar apps are grayed out. (not so with the native Email app). I figured it was a ghost in the machine, so I restarted my phone and that did not solve the problem.
Additionally, when approaching the problem (Settings > Notifications > App notifications) from the Settings menu, the offending apps don't even appear in the list of apps. I've never seen this before, therefore, I don't have a clue as to how to fix this. Any ideas/suggestions? many thanks!
if you go into calendaro -> notification categories, are you able to toggle off 'general notifications' and 'other notifications'?
yes. not the macro solution I was looking for. I learned today that Galaxy Store is also a system app. as @tismydroid suggested, this is a One UI 5.0 "feature"
jeffnachatilo
