Where do I get one of those lol![]()
A xion carnal or a robot phone?
sorry guys my optimus prime autocorrected all of my words to some other words
hey guys, i think i might be missing something. when i boot into recovery mode, the only options i'm given are:
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
naturally, i chose "apply sdcard:update.zip"
it says:
-- Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E:signature verification failed
Installation aborted.
i tried it about 4 times in a row, no results. then i renamed the kernel zip to "update.zip" and it still gives the same results. i was going to try using adb (never have before), but the SDK installer won't recognize that i have the JDK installed (i uninstalled and reinstalled just in case, still didn't work). what am i doing wrong? thanks!
you. are. brilliant. thanks, mate!
IT WORKS! YOU ALL ROCK MY ENTIRE SOCK DRAWER! i'm very excited, lol. i'll be stepping up my processor speed every 30 minutes to find a perfectly stable one, just in case. THANKS AGAIN, TO EVERYONE!
I have to take my phone into a sprint store because the hardware may be failing.
So I need to restore the stock kernel so they won't complain that I rooted it.
Do you have a link to a copy? Or should I just put a previous version of xionia on it which doesn't identify as xionia? If so, which version would that be - 4?
Thanks.
What are the source codes for and how do u flashh those. Also can I flash the latest kernel without doing the previous kernel?
i don't see the point in another kernel. the reason it's set this way is because some people (most) can run 806 without problems. others however can only get to 767 (or whatever the step down is from 806). why make it more complicated with different kernels for different speeds when you can have jsut one kernel for everyone that can be configured easily?
