October Update N10+ Unlocked
I decided not to wait for T-Mobile, so I installed N975U1UES1ASI3 (from SamMobile) on my unlocked Note10+ using Odin v3.13.3. So far, I've had no problems. I specifically checked access to my Camera settings (default camera app) and music over headphones with Google Play Music, and everything seems normal.
The firmware version number indicates that this is a security-only update.
mine said security and camera
in the pre-install info screen
You mentioned doing two successive firmware updates, if I recall correctly. Was it just the first one that mentioned those feature updates? Are they listed now under Last Update?
Awesome !!! Downloading on the US unlocked model.
I got as well unlocked model Note 10+ region india
Also got the October update for US unlocked on Verizon today. Anyone else noticed the big improvements in the fingerprint scanner? I recently installed the whitestone dome glass screen protector and notice the fps required much more pressure to unlock. After today's update I would say it's even faster and accurate than previously without the protector. I'm super happy with this update.
Thanks. I just checked my unlocked Sprint Note 10+ and the Software update is there.
The ASI3 firmware update is security-only, so it's unlikely to have improved the fps performance.
Interesting, I got the update earlier today on the US unlocked model on Verizon. I'm seeing US unlocked models on Verizon and Sprint getting updates based on this thread. Wondering if there is a pattern here.
uOttawaGrad_22
