[Odin-EC05] Froyo EC05 Prerooted/CWM v2.5.1.0 RFS (Odexed)
So I was coming from SRF v1.0.2(EXT4) and it was like the trouble shooting process was written for me.
Followed the steps
First problem: Odin stated cache.rfs....then fail(maybe issues because I was on ext4)
No biggie, just pulled the batter and flashed it with out the battery(I have no idea why this works...just weird)
Second Problem: Samsung logo bootloop, solution pull battery then reinsert and boot into CWM, wipe cache x3 then dalvik x3
No biggie then reflashed via Odin again and that passes.
Samsung logo shows up then it turns off. Any ideas?
tried it, got big red FAIL! in Odin, now my phone is jacked! whenever I turn it on, I get black screen with pic of small phone ... exclamation mark in yellow triangle... then pic of desktop.
did I just brick my phone? how screwed am I?
ok, so i tried odin without battery and different USB port. still failed with this message:
<ID:0/005> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> EC05x_DXC.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/005> Odin v.3 engine (ID:5)..
<ID:0/005> File analysis..
<ID:0/005> SetupConnection..
<ID:0/005> Initialzation..
<ID:0/005> Get PIT for mapping..
<ID:0/005> Firmware update start..
<ID:0/005> cache.rfs
<ID:0/005> Complete(Write) operation failed.
ideas? help please
<ID:0/005> Added!!
<OSM> Please wait..
<OSM> Leave CS..
ideas? help please
Same thing I had, I was able to flash without the battery but I still can't get passed the looping samsung logo...Im going to try flashing an EB13 .tar and see if that helps
I was able to reflash the EB13.tar from here http://forum.androidcentral.com/epi...68-how-factory-restore-fix-bricked-phone.html and get a working phone again.
After returning to stock EB13 I was able to flash the EC05.tar via Odin it is all working now.
My recommendation for individuals on EB13 Ext4 roms odin back to stock EB13 before attempting this.
worked great updating from EB13, but I can't turn off TW. Force close Sprint ID/TW, clear the defaults, hit home and went I select launcher it gives me a "please wait while we configure your device and services" message and then takes me back to TW... maybe it has to do with Sprint ID and being able to skin TW.
Any ideas?
Yeah I couldn't get passed samsung logo at first, just give it 3-4 minutes and it will load up... THANKS to all for the help, if you follow directions from DI18 everything works extremely smooth.
The only problem I've seen is sprint zone FC twice i didn't even realized I had it open... and then I cant figure out how to get my music player widget back to one of my pages
Will this work with DG17? I just traded for an Epic, and the Sprint Rep did a factory reset, which got rid of any updated Firmware.
It should, I have helped users go from DG27 and DI17 to Eclair and Froyo using other Odin packages.
<ID:0/005> Added!!
<OSM> Please wait..
<OSM> Leave CS..
ideas? help please
I will talk to DroidXcon, he was going to make a package for me that would "Wipe" the phone as Odin normally does. This could be "part" of the reason some people are having problems. I ran the package personally 3 times. First time I did get the boot loops, it was like 2am and we had been working on getting this together for a few hours so I might have goofed. My 2nd attempt was from EB13/CWM3/EXT4 running Baked Snack and it worked fine. 3rd attempt was from Eclair 2.1 (DI18) and it worked fine.
Don't panic friends, if get a "FAIL" you should still be fine and can simply reboot back into Download Mode and try again or flash to Eclair/Froyo EB13 and try again. DroidXcon has made plenty of these packages for his normal section the "Samsung Fascinate" and has had excellent success. I believe he removed a few things from the normal Odin packages that would be the culprit of a "permabrick" to protect you the user in case of a FAILED flash or something else going wrong.
Anyways.. I will see if DroidXcon has that new "WIPE" package ready to go and that should completely resolve any issues.
can anyone pleese post this EC05x DXC.tar.rar file on mediafire because my school has blocked everyother download site pleeeese and thanks
Hey no big deal, I knew I wasn't bricked. If anyone has issues they should just do what I did and Odin to stock EB13 then Odin to EC05 and your phone will work again. Just make sure you do a back up with my back up root and you can get all your apps plus data back, I wouldn't recommend backing up the system setting because there are always issues.
PLus it is always good to start fresh once in a while.
*Of note I was unable to get to EXT4 and CWM 3.0.0.6 using the one click method. I just got pushed into a vibrate loop after flashing the bonsaii kernel.
Started w/ Epic @ EB13.
Followed the procedure earlier in this thread. Downloaded/extracted the files, installed the USB drivers (the alternate/Samsung(?) driver install worked for me w/ Win Vista 64) before Odin could see my Epic in download mode via USB.
All in all, EC05 looks to be working, had my first exposure to Odin, am now rooted, really appreciate the time and effort to make this update available!
A big THANKS!!! :):):)
-Gary K
Easy as can be! I just did it and it took about 4 minutes. I was on EB13 with one click root.
I am at work and have no phone service, so I can't speak for any changes other than:
BASEBAND VERSION
S:D700.0.5S.EC05
BUILD NUMBER
FROYO.EC05
Thank you! Hopefully this fixes my Bluetooth issues.
EC05.TAR
can anyone pleese post this EC05x DXC.tar.rar file on mediafire and or google direct download because my school has blocked everyother download site pleeeese and thanks.
i have tried to google it and i get nada
First time having a rooted android, went from EB13 without any trouble, was much easier than I would have thought (only took about 2 minutes). everything seems to be working fine and nothing was wiped.
Thanks!
Thank you for this, it worked great! I ended up using ODIN to flash DB13, and then went straight to EC05
Worked great! Went from EB13 to EC05 with no issue. I did the manual update from DK28 to EB13 and phone acted a bit screwy. All is good now. Also upgraded 2 other Epic's without issue. Good instructions.
r3dpuk3
