[Odin-EC05] Froyo EC05 Prerooted/CWM v2.5.1.0 RFS (Odexed)
Worked great. Went from EB13 to EC05 without issue. Also did manual update from DK28 to EB13 and phone acted a bit screwy. Got tired of waiting for OTA update. Did same for 2 buddies phones, all is good. Thanks for the instructions, easy to follow.
ok, I tried re downloading drivers, tried EB13, tried DI18 and EC05. I think my phone is bricked. I can boot into download mode, and sometimes into CWM, but every time it fails. Even tried reflashing truly epic rebirth from sd card, no go. I tried different usb cables, different ports.
my phone is now mostly unresponsive. if i power up it shows a little pic of a phone some dots ... and exclamation mark in a triangle ! .....then a computer. uh. is it dead yet?
I'm eager to jump on this, but I have a question that's been nagging me for a while...
I'm running the ACE 1.7 ROM, which is on EXT4. I'm assuming my data won't get transitioned into EC05 by itself, and that I'll need to use Titanium to backup and restore.
Now, since I'd be going from EXT4 to RFS in this process, would this affect my Titanium backup? Is it able to reliably backup from EXT4, and restore to RFS, without any problems?
I've been having quite a few FC's since getting ACE 1.7, and I did restore my data using Titanium. I've found that wiping the data for the FC'ing apps (and sometimes removing and reinstalling) tends to stop the FC's. I just don't want the same experience on EC05.
Thanks for the great work! The Epic ROM community on this board is the best!
I know it sounds stupid but did you try using odin with out the battery in? That worked for me when they kept failing.
if i have apps games ect on my SD card will this delete all my data i have? like saved games and setting on my SD card? thanxs
NV just saw the 1st sorry guys!
Worked as advertised!!!!!!!!!! I had zero issues.
Thanks to all of you with the big brains and the time!
late,
Coz
Well Done! Thank you for the hard work. Once it started it took 2:42 to finish. The only issue I had was google didn't recognize my sign in so I had to put in my account pass again.
NOTE TO EVERYONE: there have been problems with the ext4 procedure for EC05 so I wouldn't do it until they update the procedure a bit.
Anyone know when EB13 Epics will get the update? are we at the bottom of the list or did I just draw a bad straw on when I'm getting it? Is there a download yet that I can use to get it?
criteriascenario
