[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
DxC... I am downloaded Super Clean EB01 2.1+root+Froyo Clockworkmod right now and see it is 345MB. Why is it so large if it is Super Clean?
I imagine, its because it has custom features ..that is a question better suited for Adrynalyne. He developed it
I went from DL30 --> EB01 (2.2 --> 2.2)
Sorry bro I'm tired I was up all night working on these when I should have been sleeping. I put 60 hours of work this week and trying to contribute here . So I'm not the sharpest tool today
That's OK. I know you put in a ton of hours into this stuff and I appreciate your help (and everybody else's here).
Final question I swear. When I flash a theme like aosp lock screen, can I uninstall it somehow or how does that work!?
Just a thought on this. Thanks to the suggestion by JaeKar99 I was able to delete old nandroid backups by plugging my phone into computer, mount sd card, and delete them from there. Would this also work for getting rid of themes, or is that a bad idea?
I also went from DL30 to EB01 and got force close issues when I restored all apps with data. Started over but restored missing apps with data and everything is fine. In fact my phone is rocking fast now.
Themes are applied on your phone I beliwve I don't play much with themes...when you remove your card do the theme shut off?
don't know the answer to that, but it's something for me to try so we can know the answer
Which one did you flash - Stock, Debloat or Superclean?
Did you just do the ODIN process over again?
I'm also having a minor problem with LauncherPro. Every time I reboot, LP seems to get stuck. One of my apps on the main screen is highlighted (usually Maps) and I have to wait. Then when I open the app drawer it is empty. I then relaunch LP and it is fine. I even uninstalled LP and downloaded again from Market, but same thing.
Maybe it was the failure of wiping your phone that's the problem.. Try wiping cache partion from clockwork
Sent from my SCH-I500 using Tapatalk
Yo DxCon, which bloat did you remove in debloated EB01? Is it just VZ crapware IE vcast,vz nav, etc, etc...... Is it same apps as DL30 leak? Any chance of a list of removed apps in debloated .tar? Thanks for all your hard work we really appreciate all that you do! I dont mean to be a PITA, there are just a few apps from sammy that I actually use, Like Media hub and a few others. Thanks for any response.
Reactions: DroidXcon
I'm thinking about going with Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod from DL30. I can't stand Bing on my phone. I just want to know if there is a way to get rid off Bing if I update to EB01? Thanks
Thanks GrainOsand, but i did not do the leg work on debloating, i just packaged it up into odin for us, that tquestion should be directed at the one and only ADRYNALYNE
Reactions: GrainOsand
DL30 superclean 1.0 with touch of blue theme
flashed eb01 radio, superclean 2.1, and the sns facebook patch
restored all apps, had force close issues
was about to ODIN back to DI01 to get a real clean wipe (at DXC's suggestion)
went back into cwm, fashed superclean 2.1 and sns patch, rebooted, went through initial setup, titanium bu with missing apps and data, no problems
EDIT*
Sorry should have specified what I meant by started over.
if you hit the search key in debloated it leads you to google but if you hit the browser icon you have bing
in superclean bing is completely removed
gurusdex
