[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
DriodX thank you for your work I used this methiod this morning and it worked ok when it loaded i went into market and it was trying to load all my apps so I pulled the batt rebooted went into market and instead of going to my apps I just searched TB and installed and re applied my apps that way everything seems to be good flashed a theme and even themed the market. Juat was wondering why it did or if I did something wrong and got lucky saving myself.
i dont know, maybe i should pull this down till i figure it out , it did the same for me, tried to download every app i ever downloaded so weird
Easy as pie! with a la froyo! Havent had it running more than 2 mins and I am already loving it!!! Thanks again to EVERYONE!!!!
thanx dxcon i did everything u n landshark said and so far everything is working as it should... i will post back if phone becomes unresponsive again for some reason
Thats your call like I said its working fine know just had a little bug everyone has to remember these are leaks and a couple of tweaks are going to have to be made. Thanks again
quick question, did you logon to gmail from the setup in the start or did you bypass all that then open the market and logon
Skiped it all and went right to market first time I ever did that normally i sign in. good call you may be on to something.
no dude, i just flashed sc and its working fine i bypassed setup.... strange because i had that problem this morning but now its running fine
I have another question I have had jts new red CW on since DL30 and have been using it with little to no problems should I flash the updated zip you have or just keeping rolling with what works
if you used my odin flash then you now have cwm froyo already installed,, is it opening,,if its not then you need to delete the update.zip if any one your sdcard and use the one i provided
Reactions: Rickaa
Hello.
I finally flashed EB01, so far, it was perfect. My only issue is that I don't have my apps. Before flashing it, I did a Titanium back up. I don't know if this was what I was suppose to do.
Can anyone tell me how can I get my apps back?
Hello.
do a titanium restore,
from titanium home screen hit the backup/restore button at the top
then from this screen hit the phone menu button
select batch
then select restore missing apps +data
DroiXcon, a million thanks....I installed Titanium again and I'm following your steps...so far, it's working!!!!!!!!!!!!!!!!!!!
You're the Man, lol
phone went unresponsive again at 3:47(i was seriously just beginning to think it was ok to put my back case back on) also battery dropped from 44% last time it was awake to 13% after the battery pull (also i just realized i am posting under the wrong thread i guess i should be under the superclean 2.1 thread sry didnt realize till now) and i should probably mention the phone went unresponsive immediately after my computer died(my phone was plugged into it charging but not mounted)
i would only bring back missing apps with data, remember you are going from 2.1 to 2.2 so things have changed,,,,,,and really it didnt format. :-! i thought i had that working...
Clak you will have to get rid of the update.zip on your sd card now because flashing rom manager replaces it...... you can use rom just dont flash it
Yeah that's what I gathered. I haven't flashed from within rom manager in a while actually, even after I flashed DL30.
ok try this, from clockwork, go to advanced , and wipe dalvik cache, and restart,
THe super clean doesn't even have touch wiz. It is stock froyo. I prefer the super clean. Just flashed SC and am loving the stock look and feel.
If I backed up everything with Titanium, and I tried a restore MISSING apps in a superclean rom - wouldn't it try to put... maybe not bloatware, but anything touchwiz that got backed up back on the phone?
no only if you choose system data i believe, but dont quote me
SophieTurner
