[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Ok tried those option to no avail. every time the phone restarts it automatically mounts. Still give the same errors
"cannot open 'rage.bin': No such file or directory"
This one comes up before phone restarts. should i be concerned with it?
means that it was deleted from the folder that you have the start root file in,,,go and redownload the folder and replace it ..if that does not work we will try one more thing
I am wondering if i should data wipe and start over. should i maybe try super clean 2.6. The whole reason i want to root is so i can attach Google to my nav like before and of course remove bloat ware except for media hub. Does 2.6 already come rooted. (sorry if i missed a mention of that somewhere in the post)!
all of my odin packages are pre rooted,,,,, use debloated, superclean doesnt have media hub
I will have 2.8 up soon :D
Will you be creating an all-in-one package like you did for the previous SC versions? After reading so many posts in different threads here and at xda I am starting to get confused about which pieces work with what. :confused:
Also, I was charging my phone in preparation for running the battery stat wipe script. Should I wait until I load 2.8nv? I'm currently on 2.6nv if that matters.
Thanks!
Ok sooo then besides bloat ware, are there any other important diff between 2.6 and EB01. I don't much care about Batt life, i have plenty of chargers for that. And question 2 then would be do i just factory wipe through normal phone settings and then use the ODIN prog to install? Sounds like this might be the way to go. I can live w/out media hub :-)
Where is 2.8 :) For some reason the one i downloaded is going through my battery like no other...will 2.8 or any of the others help with that?
we wont know until you try , but it should help in theory,,, i ran it 8 hours today and it only dropped 23%
Thank you :) I've been following you guys for a bit, i originally had the Droid when it came out but then came to the Facinate, amazing phone. Stoked to get this new update :)
I'm only seeing 2.6, would you be so kind to link me the web address for the 2.8 update...i will give you a nice review after testing the crap out of it :)
Hey SuD, I think you are thinking of ADD. OCD is when you....Ooohh look a squirrel...........I'm sorry what was I saying?
Problem is that I don't think that there is a proper classification of the person that is OCD and ADD. I believe that the designation of ADHD is being used for that, but I know me and I know that I can focus so much on one thing, to a grand fault, one day, and have no interest in it for months starting the next.
Honestly, maybe that was just my previous marriage. Grandly interested in my wife, and then one day, not so much.
SuD
Just wait a little while longer. Adrynalyne just posted the 2.8 ROM like half an hour ago. Give DXC a little more time to put it into one of his all-in-one packages
Reactions: harbormatt
SuD
I know the feeling of being OCD and ADD at the same time. Or at least feeling like I am (never been officially diagnosed.) Probably one of the reasons I'm not married yet. A wise man once said, "Marriage is like suicide boys. Do it right the first time and you won't need to do it again." :D
pns11
