[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Does it? I can't find it. I see a lot of stuff about Google Voice, but not Voice Search or Voice Commands, which are what's broken. I've been searching for info on this all night, among those with Fascinate Froyo builds, and I've found several messages complaining about it, but no one with any idea what's wrong, or a ROM developer mentioning it as a known bug.
no i meant to bring it up there lol,,sorry i should have worded that differently
when the official 2.2 comes out will you have to wipe your data also? or is it just rooting you have to wipe ?
you will have to wipe everything becaseu you will have to flash back to eclair to get official froyo,,,or you can wait till i package official froyo and then you can just flash it without wiping
thank you, i think im just gonna wait for the official since it "seems" its coming around the corner. Cause to be honest im not quite sure what im doing with all this lol
when my phone rebooted, i'm getting Force Close messages: The application My Uploads (process com.google.android.apps.uploader) has stopped unexpectedly. Please try again. AND The application Calendar Storage (process com.android.providers.calendar) has stopped unexpectedly. Please try again. AND The process android.process.acore has stopped unexpectedly. Please try again. AND android.process.media And proces com.google.android.gm At the top, all messages say to use *#9900# to take log. But i can never get past the force close messages
what build were you on before?? what file did you use?
EB16SC25x_DXC.tar
yeah if you read the warning it predicted this happening
[NO DATA WIPE MAY CAUSE FC IF COMING FROM ECLAIR] Super Clean version 2.5 - EB01/EB16 Froyo leak root+Froyo ClockworkmodTHIS VERSION DOES NOT WIPE DATA OR CACHE (TESTED by Standupdad Please thank him)RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EB16SC25x_DXC.tar
USE EB16SC25_DXC.tar
Running sc2.5 and honeycomb theme. Seems to be working well so far. Will report back on battery life. Many thanks to droidx and adryn!
very welcome, im not sure battery life will change much i still think its a modified stock kernel, but let me know :)
That would be a bummer. I went back to eclair for a few days so my phone would last the whole day.
now in the dreaded Samsung Loop:
-- Wiping Data...
Formatting FOTA:...
Formatting DATA:...
Data wipe failed.
Formatting CACHE:...
Formatting DBDATA:...
wipe_data failed.
-- Wiping Data...
Formatting FOTA:...
Formatting DATA:...
Data wipe failed.
wipe_data failed.
Try flashing odin again if that doesnt work we will try something else
Qbaumildand
