[Odin][Rom][6/20/11]AC's Altered Beast **Alpha 5** EE4 based
yea im not knocking this rom at all! I love this rom! The wake up is not a problem at all. Just noticed a a very slight hesitation.
Love the graphics and features. Not a gamer my self but do like this genre. I am having trouble with Market app. It doesn't spontaneously update or if manual update applied, it won't process..just freezes. If I do a pull-bat reboot, it will work for a few downloads then same issue occurs. some apps are not installing at all, especially when restoring with Titanium (app+data)
It is not uninstalling(downloaded earlier) or installing any apps now
Any idea why and what I should do?
Update: re-flashed with wipe data and cache. all is working properly now
I for some reason updated to the new ugly ass market and I want the one that came with altered beast. That one looks badass. If someone could help me get the. Apk that would be great.
I am just noob here, but perhaps you can just reflash the ROM and get it back???
The only thing is I don't want to lose all my other stuff and have to set up all my accounts again.
Download Titanium Backup and do a batch backup of user apps + system data, then an accounts backup. restore after you reflash and everything will be back to the way it was
Titanium Back-up!! You can do selective back-up of apps, data and system files!! Get the paid version. It's worth it for moments like this.
Update: Sorry for repeat of reply#191 above. Did not see this when I wrote mine. I agree!
What volume setting are you wanting to adjust exactly? The only sounds you would get from VooDoo is the lady's voice during the initial boot sequence.
I thought the voodoo app allows you to have better control of the sound. Make the sound on your phone louder.?
Okay, I got you now. It depends on which kernel you choose to run. The latest from jt1134, CWM Voodoo Lagfix recovery v4.0.1.0, which is what I'm working with, has a few problems and Voodoo sound improvements is not compatible.
Is the file on the first page the most updated release? Are the fixes in that file or is it necessary to add them later?
flashed over to ABAlpha5 last night and love it but my voice connectivity is now very bad at my house. Never had issues on voice or data while at home...any recommendations?
When I rooted my phone I was on EE4 and flashed the original AB to gain root, then flashed Alpha 5 when it came out. My buddy wants to root his, does he need to flash the original version 4 then 5 or can we just flash version Alpha 5? TIA!
dumpsterrentals89
