Official 2.2.2 Optimus V
Thank you very much. I've been jumping from rom to rom for the longest time. Everytime github gets a new rom I try it out. Hope to see u add that battery fix in ur next build. Only issue I get is if its off and charging the phone wont turn on. Maybe that's a safe mode built in so the battery don't over charge. I'd also love to see the video recorder messages get fixed someday.lol every rom seems to have a diffrent limit. This one is 23 secs per txt/ video msg. Keep up the great work. Oh the others seem to cut out at 15 secs.
You can power on while offline charging, just hold the power button until you see the LG logo.
H2 2.03 now has the offline charging, I just forgot to update github.
Seems like the dropbox link has expired. Can some please post the 2.2.2 recovery. Thanks for the help.
I second that. I need to get the phone swapped and for that to happen it needs to be stock. All I need is the stock recovery :-\
Easiest way to return to stock now is to flash the new update.zip from vm themselves it'll give you stock 2.2 plus stock recovery
Harmonia 1x does not have the menu setting that will brick it and it is Froyo, very stock, and works on old and new phones.
Oh, and I do have it.
I collect roms, haha. Seriously, I have almost all from the OV and OS from the last year and often ina few versions.
222ov.rar
You will need to place these in the appropriate recovery folder on your sdcard.
I just wanted to take the time to say THANK YOU THANK YOU THANK YOU for this!
Was trying to restore my phone to stock and sure enough, the file I had found had the wrong drivers for the screen - it would boot up, I would hear "virgin mobile" but had nothing. After frantic searching, now I have a working phone and the person who I am selling it to can get it :)
THANK YOU!
222ov.rar
So I have no idea how to use these individual files to restore my Optimus V back to stock from the CWM mod that is on there right now. Is there a step by step out there?
Just download the Virgin Mobile ZV9 security update zip. Put on the root of the SD card. Use the install update option in custom recovery. Once installed go to the now stock reovery and install update one more time. Thats all there is to it.
rosannejoy555
