[Official] CyanogenMod 7 discussion
Has anyone found issues w/ wifi staying on? Or is this an already reported issue?
Do you have the Wi-Fi sleep enabled to turn off when you turn the screen off?
if so go to Wi-Fi settings>Press Menu>Advance>Wi-Fi Sleep Policy
hey guys I had to go back to nand for some 4g tethering. how is #20 compare to 18? Should I give it a waltz?
20 is also the same, remember these are automated builds. Also, look at the file size, when the size changes, that means its different stuff's.
I'm back to #18 as it is much more functional for me. On #20, GPS takes too long to wake up. It does lock signal, but once it goes to sleep, i have to smack it in the head couple times to wake it up. #18 is much more responsive to GPS. I think XDA is playing around with radio settings.
Awesome thanks for the tip! Only second day on a custom rom. Any tip on the boot loop I got when trying to flash the 'bliss' theme on the xda link u posted? Is there a specific clockwork recovery version number I should use?
Do any of those themes work with build 18? I tried one (flashed the theme and then the extras) and it caused me to have a black home screen (except the status bar and lock screen were still in tact?)
I'd like this exact setup:
what would I need to do? starting from a fresh CM17 build 18 flash.
also, would there be any way to get this lock screen to work with that pictured above theme?
I'm not sure about the themes, it's hard for theme developers to keep the files current with nightly releases.
For those lock screen controls just go to menu, settings, cyanogenmod settings and I believe it's under user interface. There are some lock screen controls where you can add slide for phone/text and even choose the text messaging app.
Very.... blue.
IF you guys didnt know by now, you can skip songs by holding down the volume rocker up (when the screen is off), just sayin.
pretty awesome about the music controls..
anyone have the latest visual voicemail apk? is it still a crap shoot as to if it will work or not?
Quick, probably stupid question.
If I am using Build #17 and want to flash the new #21 build, do I have to do a complete wipe and start from scratch or can I just flash it and it'll be like an "update?"
Any help would be great!! Thanks!!
Oh, and that theme above would be amazing.
You should be able to flash it right on top, just clear cache & dalvik.
so how are these builds coming along? any major bugs still? good gps support yet?
just wondering, i'd like to give it a shot soon
Hey guys. I am running an Evo with CM7 Build 21. I use my GPS alot, and have been switching to Fresh 3.5.0.1 when needed. One thing that I have noticed in the last few builds, is that with my GPS off in CM7, the GPS signal icon in the notification bar will display with the center dot blinking. I have confirmed many times that my GPS is off, but it will still intermittently do this. Has anyone else noticed this? I have read the last 15 pages or so and haven't seen it mentioned.
Love the ROM, but this is bugging me.
Damn Dreya
