[Official] CyanogenMod 7 discussion
What exactly do you mean by screen animations? Animations when changing home screens, when an app opens up or closes type animations? I have the paid adw launcher and it comes with a bunch of animations for that stuff.
when an app opens up or closes type animations. i used launcher pro. i was just wondering.
Only thing I'm not digging so far is the return of a nuisance: 4g turns on automatically when you enable airplane mode.
I could use some help....I'm using Swype and when I miss-type something and I double click it to bring up the list of choices my phone automatically brings up the Cut, Copy, and Paste prompt and I can't get back to where I can select the word I need. I don't know if it is a Swype problem or something to due with the ROM or with the Android Keyboard. Any ideas?
can anybody help me i try the HDMI and i keep getting stuck at the evo white screen it never pass i try a clean install i try boot in cm7#14 then rebooting and flashing the hdmi, wiping not wiping, any ideas it stays like that for over 15 minutes i have to pull the bettery out in order to reset the phone and go back to recovery
It's an issue with Gingerbread that Swype is aware of and working on:
http://forum.androidcentral.com/htc...l-cyanogenmod-7-discussion-28.html#post696151
So far I've found that if you click the "Swype" button it'll give you the popup for the word directly behind the cursor. Not the best way but it'll help you get by until they have a fix.
Reactions: JCrater11#AC
Really liking this ROM so far. Gingerbread is dope! I do miss my sense a little but I'm getting better battery life with this ROM than I was with Warm 2.2.
All I did was use Cachemate app to clear.
Reboot into recovery and wipe cache & dalvik/cache twice.
Flash the HDMwIn .zip and reboot
Should take a few minutes to boot but does so without any further issues.
Once inside, look for the HDMwIn App in our app drawer and have fun :P
Any one try the HDMwIn using snes with the wii remote? I tried but just before I could load super punch out it froze. Had to do a battery pull. Didn't get to try it out again. Battery was just about dead. Don't know if that had anything to do with it or not. When I get time I will try it out again.
Just seeing what others might have encounter :)
You need the GApps APK/ZIP file.
You may have it if you DL'd the ROM with ROM Manager... If you checked the box the .zip will be on your SDCard. Boot to recovery and choose to flash a .zip from the SDCard. Navigate to it and choose it.
It should be in SD/clockworkmod/download/goo-inside.me/gapps filename should be gapps-gb-20110307-signed.zip
Good luck :). When I flashed that only the market app worked. the others would FC. I had to un-reinstall all of them through the market to make them work. Don't know if that'll happen to you.
If you didn't DL with ROM Manager I think you can get the Rom Manager .apk from their website...
Oh and the sound quailty on my camcorder was fixed on my Evo with this CM7 RC2,Thank God!
Hey BigRick.. do you know if they made some changes to the bitrate on the audio recording? Or any other changes to the audio portion that would of improved the quality in any of the more recent builds?
I think I saw a commit about it couple days ago @jrun. Not to sure.
Just in from Shinzul:
You guys will be BLOWN AWAY by how smooth the #HDMwIn beta is... I'm not even kidding, it is unbelievably fast. #teamwin
rvrsco
