[Official] CyanogenMod 7 discussion
question: I flash the HDMwIn just about 10mins ago for the first time. I first wiped the cache and dalvik then I flashed the HDMwIn. I just opened my brand new 6ft mini hdmi to regular hdmi cable pluged everything in and........nothing:(. Either I have a bad plug that I just got or i installed something wrong. Any thoughts?????
Im on build #14 if that helps.
I only had a little bit of time to play around with it, but the first time I had it running it worked just fine. I tried it about a half hour ago and I had to play around with it. Unplug the cable from tv, phone, etc. The times I did get it going I had to leave the phone but then it would go to sleep and lose the connection. After that happening for a half hour I just said the hell with it and try it tomorrow. Hope I have better luck tomorrow :). I'm running build 13
Having some RC2 issues I was hoping you all might be able to help me with.
First, the new CM it's awesome. I really like it. THe honeybread theme is fantastic, too. This is going to be great.
For some reason my home button isn't working. Both the long press and the regular press don't respond by going to my home screen or showing my recently used apps. I use launcher pro and have both the home key action and home key default screen set properly under Behavior Settings. Within the CM settings I have the Long-press home settings right under Input Settings.
The weirdest part is that I still get haptic feedback vibrations when I touch it so I know it's not the sensor.
Also, I no longer have a lockscreen. When I hit the power button to get out of sleep it just goes straight to wherever I left off. I don't know the settings here well and may have tweaked something by accident. I spent a few minutes playing and didn't see anything that looked wrong.
Hey is it Mini or Micro that we need? Cause I ordered a micro hdmi already.. please tell me I made the right choice guys
Sent from my EVO 4G using Tapatalk Pro
Yeah that's the same one I ordered for $2.04 I hope it works
Well unless I did something wrong on the install Im having no luck what so ever. I have already plug it into 2 TV's
I feel dumb (what's new haha) I can't for the life of me find where the awake time is listed in CM7. I found up time but not awake. Any clues?
This is the cable That I just opened:
HDMI to Micro HDMI Cable, High Speed with Ethernet, 6 ft , For HTC EVO 4G.
check it out:
Amazon.com: HDMI to Micro HDMI Cable, High Speed with Ethernet, 6 ft , For HTC EVO 4G: Electronics
BUT... So far no luck on getting the HDMwIn to work. HELP
I bought a cable (amazon.com) before and dont recommend it. It's very flimsy at the end. The only time I got it to work is if I bend the connector slightly. You can bend the micro connector off the rubber molding by accident since the rubber is so soft. Once it bends the pins inside gets pulled in and your cable will be worthless. it came in this cheap plastic bag like the ones that some ebay Evo cases come in.
This is the one I got locally at a local Frys store. Its only $9.99 and the rubber ends are harder and more solid which make it difficult to accidentally bend the gold plated tips on either side. Spend the extra $5 and get this instead. I've attached a close up of the cable and a picture of the packaging.
FRYS.com*|*Inland (Model : 08231)
The picture on the web is wrong but item # is the same as on my receipt (6379371). The original barcode was scanned so I'm 100% the image is wrong. But below is the actual image of the cable and the package it came in.
I bought that cable before and dont recommend it. It's very flimsy at the end. The only time I got it to work is if I bend the connector slightly. You can bend the micro connector off the rubber molding by accident since the rubber is so soft. Once it bends the pins inside gets pulled in and your cable will be worthless. it came in this cheap plastic bag like the ones that some ebay Evo cases come in.
This is the one I got locally at a local Frys store. Its only $9.99 and the rubber ends are hard almost plastic which make it difficult to bend the gold plated tips on either side. Spend the extra $5 and get this instead. I've attached a close up of the cable and a picture of the box.
I think the picture on the web is wrong but item # is the same as on my receipt (6379371). The original barcode was scanned so I'm 100% the image is wrong. But below is the actual image of the cable and the package it came in.
Thanks aznmode for that input. I thought this was turning into some comedy lounge with someone asking me if I fired up the app...REALLY!!!
EasyTap
