[Official] CyanogenMod 7 discussion
Yep.
As for SBC concerns, I switch kernels often and have 2 battery's so use at your own risk really. Nothing bad has happened to me tho.
Other kernel makers will upgrade withe HDMI drivers soon, and no SBC versions of savages will be out soon too.
I have two batteries as well. I'll stick with nonSBC
And isn't this the nonSBC version of Savage-zen?
I haven't really had any problems with CM7. I've always gotten my gps working and 4g works without any problems.
But, I noticed today that the camera app in cm7 was terrible compared to a stock evo. I had to take some close up shots of a plug and another small item or two. The focus up close seemed non-existent. Everything was blurry. Picked up my co-worker's stock evo and the pictures were much better and in focus. You could hear the autofocus kicking in before it snapped the picture on each, but my camera ended up blurry every time. Lens cover doesn't really seem scratched and I'm seeing fairly good pictures in normal situations.
If this something others have seen? Is the camera app just not as good on cm7? Not a big deal to me either way, just curious more than anything. These were fairly closeup shots and within 6-12" of the item.
I've never used the CM7 camera app. I've been using Vignette since the first week I bought my Evo. I thought everyone dumped the native camera app... or at least they should. ;)
Yep.
Thanks. I been reading alot of people having trouble with not having the HDMwIn working with SavagedZen-0.2.0-CFS-HAVS-WiMAX-GB-signed.zip
kernel.
i just flashed the nightly 21 now i cant get data connection :( i try going back to sense rom and i got a message saying my user name and passwork is incorrect any help please i need my data connection.
my wife says when she try to send me a txt she get a message saying the costumer is out of service?
does anybody know how to reset the data conncetion??? i already try going to settings and update prl on sense rom but nothing works i try to go back to #19 and nothing :(
Try updating profile on a Sense ROM. That may fix it.
I need to get with Cyanogen and find out why the Update Profile / Update PRL haven't been brought across to CM.
how do i do that? i try updating the profile on sense rom i the phone get stuck saying Device configuration/the network is preparing your services...
any help?
then i got a error colde 1012
any help?
From SprintUsers:
Error Code #1012: Could not prepare data services. Please try again later. If the problem persists, you may need to contact Sprint.
Client-initiated IOTA fails, general failure code for all IOTA failures.
This is a Mobile IP address error. Usually caused by your IP address not being recognized by the network, and expressed as an incorrect username/password.
I'm not sure where to go from there. You will probably need to re-program your phone from a Sense ROM but I do not know exactly how that's done off the top of my head.
From SprintUsers:
i found the problem... what heppened was as soon as i flashed the 21 my account with sprint got disconnected, so i automatic tough it was the phone...
sorry about that guys, but thanks for the help...:)
Hey guys is there any work around for the GPS to work in the newer CMs? My GPS turns on but some apps says its not and others (like google maps) say I am a block away from where I am really at.
Man all these nightlys are showing up too fast and cant keep up. Anyone know what changes or updates were made to #21? I currently have #19 and I'm wondering if I should upgrade. 19 is great so far.
Just checking if anyone is having anyluck with this kernel,(SavagedZen-0.2.1-CFS-HAVS-WiMAX-GB-signed.zip
MD5: c0414a87d5124b3ed74d4af4d9ec3954) and if it's working yet with the HDMwIn apps. I was reading alot of people on the XDA formus were having a cable unpluged problem with the 0.2.0 kernel.
I have tye same kernel and its doing the samething to me.
Sent from my PC36100 using Tapatalk
oguk
