[Official] CyanogenMod 7 discussion
When upgrading nightlys, should you flash the cache before or after the update is applied? Also if using rom manager, is there any way to have it do this? The only option I see is to flash the data and cache, which apparently doesnt need done between nightlys. Thanks!
This probably isn't CM7 related, but just incase it is because of the version of the music player(?).. i'll ask anyways.
When i launch the Music player app and select artists. For instance, if i want to play some Black Keys, it says "Black Keys - 6 Albums" And there is no way for me to just select the first song and have it play them all, because its breaking them up into albums. I can't seem to find an "All Songs by Artist" type option. Am i just blind?
How do I turn that off?
I was just joking bro aha!! but do you have Haptic feedback on?
Cause i know when im on the phone my screen turns on automatically and if that's happening than maybe your face is making those go off.
but that's a maybe :/
I'm running nightly #19, and I've noticed that while my phone is charging and gets to around 90%, the green notification light turns green. I know the battery never fully charges but it's just weird having it come on early. Maybe it's my kernel: SavagedZen 0.2.1?
It's not your kernel it does that for alot of ROMS :D
Reactions: Go Android!
That's normal for AOSP
Even though the led is green it will still go to 100 if you keep it plugged in.
Are they new versions of themes? Cause I'm using honeybread and the battery never changes it always stays green even with a reboot and this is with any theme that changes the color of the battery. I already reflashed the rom twice and it keeps happening.
kankuraon
