Official/Unofficial 2.3.4 Gingerbread RUU Leaked
Anyone know how to get the phone to stop suggesting WiFi access points for every single program that might use data? Not a huge deal, especially with all the other improvements, but very VERY annoying. :eek:
Are you using toggle or going in to settings...... I used settings and when screen popped up I selected "never turn on Wi-Fi. It's worked for me so far. Used a few different apps and cycled Wi-Fi on and off for testing.
I really would like to know how to update without wiping the phone. Is it possible to do?
I don't think you can sideloading a ROM like this RUU. Some OTA can like MR1 and MR2 could.... With some apps not liking 2.3 verse 2.2 I'm not sure want to without wipe. I just back up all of my data (several ways USB and apps)
Thought I did. Just went into settings and its checked. We'll see. Thanks for the input
I updated without wipe any data and runs smother and faster and until now everything works great. Battery Life seems the same. Though I like the new graphs on battery use...
Sent from my ADR6400L using Tapatalk
Apparently someone did.
I have been having my Tab 7" for a few months and don't know anything about installing leaks. Can I use this leak on my Tab.
I'm going to take a wild guess and say NO. This is made specifically for the Thunderbolt. You'd have to look for something for your device.
Hi all, I'm currently downloading. When I go into explorer I just right click this file and click Rename --> Call it "PG05IMG.zip" correct?
Yes, but first verify md5 then place it on the root of your SD card. Then install through hboot
There is a newer leak out now though. Not sure why you would want this one.
Could you please link to where this new leak is located?
i installed it and it runs great but my superuser wont work. does it unroot my phone when i flashed the update???
what's the deal with mobile Hotspot working on my phone again? Running unrooted gingerbread working insanely fast and a working hotspot...
ajr81
