[Old version][Guide][Samsung] How to flash Stock ROM via ODIN
Status
Not open for further replies.
Re: [Guide][Samsung] How to flash Stock ROM via ODIN
Please help. I rooted my galaxy s4 using the Kingo Root program. I decided to unroot it using a stock firmware using Odin3 v1.85. I've followed the tutorial carefully. Unfortunately Odin keeps failing me. I've run it on administrator, and change usb ports but it still failed.
<ID:0/009> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> G360HDDU0ANL3_G360HOLB0ANL1_G360HDXU0ANL4_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/009> Odin v.3 engine (ID:9)..
<ID:0/009> File analysis..
<ID:0/009> SetupConnection..
<ID:0/009> Initialzation..
<ID:0/009> Get PIT for mapping..
<ID:0/009> Firmware update start..
<ID:0/009> boot.img
<ID:0/009> NAND Write Start!!
<ID:0/009> recovery.img
<ID:0/009> system.img
<ID:0/009> SPRDCP.img
<ID:0/009> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Tried different cables? Is the file correct for your phone? Have you tried downloading it again?
thank you so much, ive been trying all day to flash the stock rom, and have been flashing to the bootloader section, but now i think it will work.
Welcome to the forums. Sorry for the delayed reply, did everything go well?
From an AOSP M8
anyone knows where i can download stock rom for galaxy TAB PRO 12.2 SM-T9000ZKAXAR? i have a popping sound problem on my tablet and B.Diddy suggested that i should flash my tablet to stock rom and hope it fix it. Thanks for the help guys!
Have you tried either Sammobile or Samsung updates?
From an AOSP M8
Thanks for the reply and yes i did. Still doing the same thing. I factory reset my tablet again today and see if it fix. But i also want to try to flash it and see if it fix the problem.
The SM-T900? I found this: Firmware archive | Samsung Updates
Now the question is which region code do you have? You can look in one of 2 ways. It should be on the box within the model number, or you can download a PC program called Kies, which can be found on Samsung's website, and look it up that way. Kies should be able to restore your stock ROM too.
hey if i update grand 2 using cp is there any problem.... please tell
Welcome to Android Central! I am afraid I don't understand what you mean by 'using cp'? Can you rephrase your question?
thanks for reply. Another question is, if i plan to root my tablet will i be able to update my galaxy tab?
No. Once you root, you have to unroot (and I have seen superuser programs starting to fail at this even though there is a full unroot option), flash a stock ROM, or go with a Custom ROM to stay up to date.
thanks again for the reply. I just hate this samsung bloatware. kinda scared rooting my tablet since i bricked my transformer prime.
Hi I did everything as you said and odin said pass so it went ok but i still cant get passed the Samsung flashing logo screen on my Samsung galaxy s3 from T-Mobile, please help.
Thank you very much, that did the trick!
Sometimes the device gets stuck after an Odin flash. Rare, but it happens.
Glad it worked. See you around the forums!
Glad I read this. I plan to do this tomorrow morning to go back to KitKat. Lollipop is horrible. Quick question: doing this doesn't require your phone to be rooted correct? I have a galaxy s5 on Verizon.
Status
Flykxd133
