[Old version][Guide][Samsung] How to flash Stock ROM via ODIN
Status
Not open for further replies.
Re: [Guide][Samsung] How to flash Stock ROM via ODIN
Golfdriver97 I really DO LOVE YOU!! I am a terrified newbie who has spent DAYS reading and anguishing about starting this process. I have rooted 2 devices and felt almost as leary to begin as I did this process. I was really unhappy with my Samsung Note 8 (GT-N5110) being stuck on Android 4.1.2 when lots of other countries have got the upgrade to 4.2.2. I just followed your guide and it was perfect! I can't thank you enough. It was comforting to see a step by step instruction posted with pics to boot! Thanks again!!!
Glad it helped. Thanks for the shout out. See you around the forums.
From a Sprint Moto X using AC Forums app
In the event you think your stock ROM is faulty, or you want to flash back to a previous version on your Samsung device, here is how.
[INFO]This is for Samsung devices, and a general guide at that. Some carriers may have more detailed steps that need to be taken. I cannot guarantee how well this will work for every device.[/INFO]
thanks for the great simple easy to follow guide! just a few questions please.
I have a Galaxy Note 8.0 model GT-N5110 WIFI i just rooted last night using CF-Auto-Root and it went well so im rooted now. Im in Canada and we only have 4.1 available to us so i am on official firmware 4.1 and rooted. i would like to upgrade to 4.2 just so i can move apps to ext SD Card because im running out of storage. i have installed currently busy box, super su, multiwindow mangager, and xposed framework.
for me to upgrade to 4.2 what do i have to do? thanks in advance.
[NOTE]The things you will need:
- Download and install ODIN
- A program called 7Zip
- A copy of your stock ROM in question.[/NOTE]
Odin is a program that can utilize the MD5 file to install ROMs to your device. MD5 files can be anything from recoveries, modems, and even ROMs.
First, one of the things that may need to be done is to update your device drivers. You can do this one of two ways.
-You can search the net for your updated drivers. Download and then install to your PC.
-Or you can download or update Kies. Part of those processes are to install or update drivers.
Once drivers are installed, a restart of your PC may be required. In fact, I would highly suggest it.
Second, is downloading and installing 7Zip. 7Zip is a file extraction program, that unzips compressed files. Windows has a file compression and decompression program as well. Depending on where you get your file from, having both is handy in case one works and the other does not.
Third, Your copy of your stock ROM. This will be the compressed file you downloaded. You will need to extract it. The best thing to do is create a file on your desktop. This will make the extracted file easier to find. Once created, you can right click on the downloaded file and click Extract. Either program will ask where to extract to. Click on the small box with the 3 dots and navigate to your desktop and locate your newly created file.
Next, you will need to download and install ODIN.
[TIP]Once done, you should start it by right clicking and 'Open as Administrator'. This option works best for using ODIN in general.[/TIP]
This is ODIN just after the program has been launched.
The MD5 file would go into the PDA box. Sounds weird, I agree, but the PDA box will be your best friend. You don't need to worry about any other Boxes.
This is the PDA box that will be needed to flash any file.
Once the file is in the box, you would now need to turn off your device, and reboot into Download Mode by holding volume Down and power (If using the Galaxy S3 and 4, Home will also have to be held).
This is the first step to getting to Download Mode.
This is what Download Mode actually looks like.
Once in Download Mode, you can plug in your device. You will need to wait several minutes, as ODIN, your PC, and the device all talk to each other.
After some time has passed, upward of several minutes, you should see a box that is colored and has a type, and a number: Ex: 'COM:6' That means your PC recognizes the device and everything should be ready to go. The number is irrelevant.
Note the COM:3, and the MD5 file in the PDA box. Now, to begin, just click Start.
[WARN]At this point, DO NOT remove your device until ODIN says finished, or if something goes wrong, it will say failed.[/WARN]
ODIN flashing has begun.
When ODIN is done, you should see a box that will say reset or passed (depending on which version you have, you may see either or both.). At this point it is ok to remove your device.
ODIN fishing up it's process. Testing the reset.
ODIN has completed the flash, and by now, the device should be going through the reboot screen.
Any problems, try these few things: Update Drivers, and restart your PC; Different cables; Different USB ports.
Other solutions may include redownloading the file.
on official firmware 4.1.2 note 8.0 gt-n5110 just rooted using cf-auto-root. want to upgrade to 4.2 so i can move apps to ext sd-card. i currently have xposed frame work, busybox, multiwindow and super su installed? can i still use your guide? or are there different steps i have to take to upgrade my official 4.1 (rooted) to official 4.2?
Only if there is an official 4.2 ROM for that device.
From a Liquid Nexus 5
I'm new to this. I've found a site sammobile.com are these official firmwares? If they are and I use this through Odin will I loose all my current apps? Do I have to triangle away or unroot prior to upgrading to 4.2?
I can't answer if you will lose your current apps. I thought I'd mention that I used Triangle Away to reset flash counter, then unrooted using Super SU, and removed any root necessary apps. I then flashed a rom I downloaded from Firmware archive | Samsung Updates and picked the one with 4.2.2 firmware and region BTU which is from the UK as I of course wanted English. Then I put it in a folder on my pc desktop after it finished downloading and unzipped to that folder. Follow Golfdriver97's excellent instructions and when you are finished you will be on 4.2.2. I just checked my flash counter and it says "no". So that is good. I may still root again but this time will use Saferoot as it doesn't trip the flash counter either I am told.
- - - Updated - - -
I should have mentioned that I don't think I lost any apps when I did the above.
- - - Updated - - -
If you don't mind you think you could explain to me how to unroot using super su and removing root apps? I'm new to Android - Note 8 my first Android device. I'm familiar with blackberry and apple devices and computers this is a new world for me. Your help would be gladly appreciated.
Reflashing a stock ROM should fully unroot you. All of your apps will be gone, and it will be like starting the device all over again.
So Golfdriver97 says your apps will be gone. That answers that. Have you downloaded and installed Kies from Samsung. Kies is their program for backing up and restoring devices and also for moving music, movies, etc to your device. I don't use it cause it doesn't transfer my iTunes playlists. I use iSyncr (I use the mac version but there are both in the play store). It is an awesome app. I just go into iTunes, and I make up playlists with movies I want transferred to my N8 and then use iSyncr to 'sync' it to the N8. There is another app made by the same people as iSyncr and it is called Cheetah. It is great for transferring documents, pics etc. You might be able to use iSyncr for pics too, I can't remember off hand.
Oh and by the way, if you are downloading the firmware file I mentioned in a post above for 4.2.2 it took me hours for it to download cause I don't belong to whatever service was hosting the files. I started it and went to bed. It was done at some point overnight.
I've had more than one iPad and really prefer my Samsung tablet. It is very different than iPad but very customizable. I also used to have an iPhone and switched to Android, namely Samsung Galaxy S3 to start, and last October I got the Note 3. Very customizable. Apple devices are not which is why I don't prefer them. Their app icons are so kindergartenish. I'm now a big android fan for the past year and a half.
Thanks for the tip. I'm not an iPhone person myself. Could you tell me how you unroot with Super Su and remove apps that need root. I'm new to all of this.
Backing up a moment: Both Sammobile and Samsung Updates have libraries of official Stock ROMs. Recently, Samsung Updates made changes to their site where a free download now takes minimum 3 hours (at least for me and I have 25 mb/s down) and I, personally, find this unreasonable. Sammobile still takes a while (about an hour) but I do understand throttling that speed, even to a degree, for free use.
Now, to your question: There should be a full unroot option in settings of Super SU. Reflashing a stock ROM should also remove root access.
Golfdriver97, thanks for the excellent tut! Clear and concise really made a first time rooter like me brave enough to flash a newer OS to my Note 8.0.
macbook5 thanks for your support also everything worked out great without a fault. Best part is all my apps stayed!!! I know have that coveted desire to move my apps to SD Card - FINALY!!!
On first reboot Super Su nowhere to be found. Play store seemed broken couldnt connect for its life and google keyboard also kept crashing and lagging up the system. Yes i was in deep panic so i rebooted again with problem still persisting. ultimately i uninstalled Google Keyboard tried play store again and voila play store worked and was able to re-download google Keyboard.
SuperSu also didnt install so downloaded from play store. i still couldnt get Super Su to work it kept crashing on me. My guess is that when i re-rooted to flash 4.2 some of SuperSu installed but not all? Anyway went through settings on super su and uninstalled through super su. Once that uninstalled itself i reinstalled through play store and now it works.
Side note i really liked having any app to run in multiwindow so i downloaded multiwindow manager from playstore and that require xposed framework and another module so installed that also. as i was setting up multiwindow manager it asked to patch a system file so i pressed next once it asked me to confirm my tab model i was only shown GT-N5100. Here i hesitated because i was afraid to "brick" my device. I emailed developer through the address provided in the play store and i received a reply. He sent me a link to another version through a dropbox link. So now i have an appropriate multiwindow manager for my actual model which is GT-N5110 (WiFi)
Sorry I have been away for the better part of the day. Busy at work. Glad you got everything taken care of.
Do you have any questions about Xposed?
thank you :D this is so amazing my phone is stuck in 1 week and i read this my phone work again
thank you thank you very much!!!!!
I'm glad you are up and running again.
Hi, will I loose my data following this guide?
Welcome to the forums.
Yes. Back up anything you don't want to lose, and proceed.
From an SOKP Nexus 5
You saved me! I'd bricked my epic touch -- no usb, frozen on lock screen. I have no idea how it went to download mode -- I turned it off and turned it back on which I'd done dozens of times post-bricking, then suddenly it started downloading. But I'd never have realized it wasn't downloading anything unless I guided Odin to the rom, which was apparent solely due to your wonderful guide. My EFS was gone and now it's back, as is the working usb driver! And, it rooted just fine using framaroot. Wow. I'm giddy with excitement. Thank you soooooooooo much
:-*:D
:-*:D
Glad you are up and running. See you around the forums.
From a Slim M8 and the AC Forums app.
Im only having issues with getting the Samsung SGH-I727R doesn't ever register in Odin. I have the device in download mode, and i have the TAR in the AP box, just waiting for the COM## to show up, which hasen't. The device constantly reboots and im hoping reflashing the stock firmware resolves the issue.
Status
sellhousefastmke
