Optimus V (Virgin Mobile)
Receiving permission denied when I try. Anything else to try?
Sent from my VM670 using Tapatalk
They've got a dump over at sdx. Apparently if you keep trying it'll work eventually.
To get a dump of the ROM, do the following:
1. Connect phone to computer via USB cable.
2. Enable USB Debugging in Settings->Applications->Development
3. Open command/terminal window
4. Type "adb pull / C:\systemdump" (without the "")
5. Navigate to the root of your C drive, and compress the folder labeled "systemdump" into a .zip archive.
6. Upload the .zip archive to a website like 4shared, Mediafire, or Dropbox.
Root privileges are only required for writing to the phone, not pulling.
Ahhh, I gave him code with forward slashes...
Got it. Uploading now.
Thanks!!!
Just get "Hotspot Widget", and you can bypass the hotspot block. I tested it and my old Pre picked up the access point. No rooting needed.
It does appear to activate the hotspot feature in the phone, and I can use the widgets notification icon to configure the hotspot. The network is visible to my Win7 laptop, and I can connect. But there, the fun stops. It's the dreaded limited connectivity situation. Anybody have any better luck?
BTW, I got my V at a Target a couple of days ago. Interesting story: I called to inquire about it. The guy in electronics said that he'd never heard of it. I offered the internal Target stock number. He looked it up, and said, "Can you hang on?" Duh, yeah. After what sounded like a long walk, he said, "Yeah, I have one right here." "Can you put that behind the counter for me? I'll be right there," I say. He says, "I'll tape your name to it, and take it up to customer service. You can pick it up and pay for it there." Of course, I already had my jacket on by the time this conversation was over. Picked it up and it activated just fine (already had VM service, so I just used their website to plug in the new ESN, and I already new how to program the phone number and network ID into the phone). I really like the phone - it's easy to see why so many carriers have them, and why so many people have bought them.
Sure enough! Don't have XP, but I tried it from an Ubuntu laptop, and it connected (and functioned) just fine. Did a Speedtest.net while connected. Got 1.0 down, and 0.5 up (which is within the range of what I have gotten on the phone), and the test confirmed that I was using Sprint PCS as the provider.
Now, why is Win7 giving me a hard time? (rhetorical question)
What's the Target stock number?
That's exactly how I did it. I'm not even sure if they were really supposed to sell it or not.
thanks for the info. i heard that VM use old towers from Sprint, so VM signal quality might not be as equal to Sprint's?
Also, VM cannot roam, am i correct?
In my experience coverage is the same. VM doesn't have 4G like Sprint, but otherwise is identical, but YMMV. And you are correct, there is no roaming.
I have heard in the optimus s forum that you can change your PRL to include other's tower as in-network. I wonder if we can do that in optimus v (and VM) to add the standard sprint roaming list back?
That's something I don't know anything about, but it might be possible. Also, it seems like that would be something VM could track and kick you off their plan.
I work for Target (pays the bills while I'm in school) and yes, we are allowed to sell it. The reason for it not being on the floor? Varies by store. The main reason in most stores is that they haven't been sent the signing, materials, and display yet. We're working on it though :P
Any one know how to get mms to work will not send or receive? Not with stock or handcent messanger
liquidsnake757
