[OTA][9/21] Official Jelly Bean JRO03O for the Verizon GNex
Let me make sure I understand this right, I'm currently on IMM76K, that means I can't go straight to the OTA update file? I need to update to IIM76Q first? Thanks
Did you see the first post? I make it clear there ;). Two files meaning Verizon is updating both current 4.0.4 builds.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
I'm on the leaked update. It works great. Should I be hard pressed to flash this 9/21 update? Since it appears to be the same, I want to stay on this leaked version. What say you all?
Nope. Same deal from the ye ole eye ball test.
Sent from my Overly Suspicious Robotic Grouper
[FIXED] I keep getting assert failed: getprop("ro.product.device") =="toro" || getprop("ro.build.product") = = "toro" E: Error in /sdcard/download/60fc80848c8e.signed-mysid-JRO03O-from-IMM76K.60fc8084.zip (status 7) Installation aborted.
Please haaaalp!
***EDIT*** Just for the hell of it I tried flashing it using TWRP recovery instead of CWM and it worked like a charm.
So I woke up to Jelly Bean being installed on my phone this morning and now every time the screen locks, the notification light stays on. Anyone else notice this? And no there are no notifications that I have.
Re: [OTA] Semi-Official Jelly Bean JRO03O for the Verizon GNex
so if I already flashed the leaked build JRO03O, which is actually the official build, I am all set, yes?
I upgraded my friends nexus to JB Straight from 76k.
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
mine keeps failing, tried to go to Q from K and then tried the jelly bean update from K.
I'm getting status 7 error on both cwm and twrp.
assert failed: apply_patch_check("/system/build.prop", and so on
I've never edited this directly, could an app have done this?
If I have the earlier update will I still get this one
The reason I ask is my baseband is i515.10 and my wife's is i51509
Sorry if this had been asked, but in getting a system 7 error then aborts. Can someone tell me what I'm doing wrong? I'm stock rooted in imm76k. Thanks
It's a hardware revision, no difference really.
You have a custom recovery, you need stock recovery to take the update.
Just as 2defmouze said, it's hardware revision and no one has a clue of what it actually changes.
It says to use a custom recovery on the steps on first post.
Ohh.. misunderstood, thought we were talking about accepting the OTA, lol.
What recovery are you using? Specifically version#. Make sure if you are on CWM it is 6.0.1.0, or if TWRP then 2.2.1 (I believe). Basically you want to make sure its all up to date. Also make sure you are using the correct OTA file, as I believe there are 2, one if you are coming from K as you say and one for people coming from the Q build.
Yea I'm using cwm 6.0.1.0 and correct file. Even download file again. Hmmmm
r3dpuk3
