Just flashed this over my (nearly) stock IMM76K. So far so good!![]()
Just out of curiosity, what happens if you don't have the custom recovery and upload JRO030 from IMM76K?
Now that I'm on 4.1.1, can I root?
Of course you can! Simply download this file, place it on your phone, reboot into recovery and flash it. When your phone reboots, update the binary. Then, go to the Play Store and update the app itself--SuperSU. You can also try this superuser zip--Superuser 3.1.3.
Ive got no problem with the flashing of the ROM but I did have a question about the rooting.
The binary, how does one update that and is there e benefit of the superuser zip. Im already unlocked and rooted.
Is the OTA update the same as what was earlier released?
The Superuser zip has both the binary and the Superuser app. You need the superuser app to update the binary and essentially "use" it, i.e. through granting permissions to different apps.
Check our radios thread. I posted my own dropbox mirror. Get it while it's hot.
Or...
https://dl.dropbox.com/u/61778374/411_radios.zip![]()
I have been using the unofficial update (THANKS DMMARCK!) for a little less than two weeks now and it has been great. I was fully intending to go back to stock and take the official update when it came out, but being emboldened by my success so far I am thinking of rooting and trying out a custom ROM.I am just not sure which one to try out first...
Everything went perfectly, except now I can't flash into recovery to re-root my phone. When I try, I get the laying down Andriod icon with the red "X" and I have to pull the battery to re boot.
Is an older build than sprints 3U build?
---------- Post Merged at 12:30 AM ---------- Previous Post was at 12:30 AM ----------
