OTA link
I'm getting the following issue -
E: Can't open /cache/recovery/command
Finding update package...
Opening update package...
Verifying update package...
Installing update...
assert failed: file_getprop("/system/build.prop" . "ro.build.fingerprint") == "verizon/inc/inc/inc:2.1-update/ERE27 /161494:user/release-keys" || file_getprop("/system/build.prop", ro.build.fingerprint") == "verizon_wwe/inc/inc/inc:2.2/FRF91/231334:user/release-keys"
E:Error in /sdcard/update.zip
(Status 7)
Installation Aborted.
Awesome! Thank you for getting this out. Everything is great except for swype, it doesnt work now.
The update worked for me also.
To this poster here are the details on how to do this:
First download the file which you find in this thread. It will go wherever you save it. Save it to your desktop on your computer. Do NOT unzip the file on your computer. Leave it exactly as it is on your desktop.
next...
Plug your phone into your computer. Click your SD card. Drag the file that you downloaded into your SD card. Not in any of the folders you have created on your SD card. Drag it as if it's an entirely new folder.
next...
Rename the file, you can do this on your computer. After you dragged it right click it and rename it. If you have extensions hidden it will not show .zip. In which case it will just have the file name with no .zip at the end of it. So just name it, "update." If you do have extensions showing then make sure it says, "update.zip." Again, if you don't have the extensions to files already showing, meaning if it doesn't already say .zip then don't add .zip too it.
next...
Power your phone off. Once off, hold the volume DOWN button down and press power at the same time and wait for it to power on. Once powered on you will see a boot screen. Scroll down to recovery with your volume rocker and hit the power button to select it.
next...
You will get a blank screen with a red triangle. At this point hold the volume UP button and press the power button at the same time. Now it will appear where it says something in the nature of putting on, "update.zip." Scroll down with your volume rocker and push the power button to select this.
next...
It will install. After done installing it will bring you to the screen it was previously on. But this time do not make the same selection. Select, "Reboot phone." Push the power button to select it.
now...
It will install and reboot your phone. It may take a few minutes. Once the droid eye screen comes up it will remain there for a few seconds. Do not freak out. It is fine. This is a good link and it is not buggy.
then...
Your phone will turn on as usual. You will have all of your apps, all of your settings, all of your ringtones set, the same wallpaper set, everything exactly as before. You will notice some changes they made to text messaging, changing the keyboard and many other things. As well as speed.
Any problems?
With me I have run into no problems at all. The clock and weather are working fine and so is every app I've tried. I've deleted Advanced Task Killer, it doesn't have much use these days anyway it doesn't sound like but especially not with 2.2. If you kill apps within a minute later all of them almost will be back and running unlike 2.1 where they would stay gone a little longer.
The signal bar has been changed for a fact. I am getting full signal bars in my apartment where as on 2.1 I never did and the bars are staying full. The service is probably no different but they fixed the way it reads the service with the bars to be more accurate.
Anymore questions then ask. I have never done anything of this sort myself until tonight. It took me a little while. The mistake I made first was unzipping the file on my computer and then dragging it to the card and renaming it. Don't unzip the file. Don't touch the file in anyway on your computer until it is on your card and then you only need to rename it.
It is also important to know if you have extensions hidden or not. If you do not see .zip on the end of the file then they are hidden. So do not name it, "update.zip" Or else it will end up being, "update.zip.zip." Simply name it, "update," if this is the case.
thanks! worked perfectly and only took 15 minutes!
I'm sorry but is it just me or is the screencap on the front page showing the 2.05 radio and the RUU is with the 2.15? I thought these were supposed to be the same.
Awesome, rockin froyo now, downloaded using my phone, which was good being that I forgot my cable today....was getting worried I'd have to go scrounge around the office looking for a cable.
Justin
(Status 7)
^ getting the same issue. i tried on both disk drives
Not workin for me either......Signature verification failure. I deleted the update.zip from the sd card. I will wait for the ota i guess.
I am stupid and named it update.zip when extensions were hidden, so it was update.zip.zip and i kept getting an error. Was gonna give up and decided to delete the .zip from the name. Phone is rebooting now and I'm giddy with excitement!
Thanks, OP and logan. Only disappointment is that the update didn't repair the cracks in my screen. #highhopes
worked!
Thanks for posting this and the instructions. Easy once copied and renamed from my pc.
Steve
(Status 7)
Bumping this issue, any solutions?
Okay I did the update without any problems. But now when I start it up, I get this droid splash screen with the red eyeball and semicolon at the end just before it goes to the HTC UI home screen. Is this normal? Isn't "droid" Motorola's trademark?
Woot!
Thanks Teslatech!
And score a BIG ONE for the AndroidCentral community for SCOOPING THE WHOLE INTERNET!!
next...
next...
next...
next...
next...
now...
then...
Any problems?
I did exactly that and when I goto hit the install update.zip it says file doesnt exist and it aborts the installation... Had this same issue with my Droid when I was rooting it...
CliffHangerOld
