Overclocking For 2.1
so if im on fresh 2.1.2 can it be oc'd? i like my rom, but it needs some speed...tried ocwidget, obviously it doesnt work with it<or if it does i have no clue whats wrong> i saw the 1st post, but i didnt follow if it works with this one....thnx peepz
I would grab the zips to flash for oc on xda for flipz rom,these might give you problems.
i messed with the settings a bit and it seems better but still overheating when on my charger in my car (this is mostly when it is overheating now). Before it was also overheating before I woke up, like if i had missed calls and the screen was locked but on (Stock lock screen with swipe pw) Here are my current settings:
Standard: 768,614
Charging: 537,480
Sleep: 537,480
Failsafe: 537,480
(Seems to work better now with sleep and charge set the same) Upon looking at these and thinking some more I am going to try:
Standard: 768,614
Charging: 245,480
Sleep: 245,480
Failsafe: 245,480
Yeah i would try keeping it low like that when charging.The highest i go with screen off is 480.
*Also have a good road trip,let us know how the radio and oc'ing goes.
rotf, yeah it does get that hot sometimes when its charging and running something like wireless tether.
So,I tried using the oc on first post.it worked but now I don't have live wallpaper. Ideas...
Not sure how it would mess up livewallpapers,but did you make a nadroid backup before you flashed it?
I have rooted, installed roms (Using yours brezzy) but I have no clue how to flash just the kernel. Can you point me in the right direction? I have searched and found nothing. Do I simply use fastboot flash boot OC-kool-aid-boot/boot.img?
Its very easy just download the oc zip place on sdcard then reboot into recovery then just flash the oc zip,don't have to wipe.Its flash just like a rom.
I installed the Overclock and adjusted to the recommended settings but it wont go any higher than 528mhz. Whats wrong?
Did you flash the item on the first page? That has to be flashed first, then install the widget. Newer kernels (im not running this specific one, so i don't know if it applies to this one) still show the maximum at 528 in the settings, but my OC widget is running over 600 everytime i check it.
oops.... I guess that would help. Thanks.
Edit: it is now OC'ed at 768Mhz.
BNIRECT
