Pending messages
Do I need to install a ROM?
If you install a custom ROM, I'm not sure if you'll lose your unlock or not...I'd say do a Factory Reset, just back up your Apps, Text Messages, and Contacts and just do it and hope it works out.
I wouldn't flash a ROM especially if you don't know what your doing,if your stock just reset but BACKUP first,see if that helps
Sent from my DROID RAZR using Android Central Forums
I'm having the exact same issue. Upgrade my AT&T phone yesterday, texts worked just fine all evening. This morning I can recieve texts but not send them. Did you ever find a way to correct it? I already spoke to the AT&T helpdesk, they say it's nothing on their end. They want me to take the phone back to the store because "its faulty" but if i'm not the only one having this issue how would a replacement vivid solve the problem??
TomyJones4567
