Phone battery and CPU overheats in minutes while doing nothing and it has weird problem with audio
elpatho
7
CPU and battery temperature (according to some apps) climb up to high temperatures in no time. Whole phone is super hot and laggy few minutes after starting it up.
It has probably something to do with jack and audio. When I try to play sounds from speaker, the phone just lags and start to heat up even more and is unusable. When I connect headphones, the audio plays but the phone start doing weird things like randomly going to silent mode and works only left headphone. It started randomly one day without any prior problems (expect the fact that sometimes my headphones put my phone on silent mode and the buttons for pause and play on them stopped working).
Its not software related because I did factory reset, uninstalled everything, disabled wifi and phone services and even installed new OS and the problem is the same every time.
I have Nexus 5X. Its 5 years old, but its still in great shape (or it was before the incident) so I would like to fix it rather than buying new phone.
It was badly worded sorry. By incident I meant that it happened one day out of nowhere. But I connected speakers to the phone and the phone restarted. Later that day it started to do the things I mentioned. That day I thought its nothing, but with issues with the audio I think it can be related somehow.
Yes, they were large speakers with amplifier. But I connected it through ordinary jack cable. Also I made a mistake and inserted the cable in the output hole instead input of the amplifier. But other person did the same thing and it didnt do anything to his phone. Or computer.
They probably got lucky , you didn't :(
It may be worth looking at ifixit or jerryrigevergthing on YouTube for a teardown of the nexus 5x if they have one on there. That would show you if the jack is easy to replace or not.
But I dont understand how fried jack can do all the overheatings and problems with audio. It sounds like it started there but some more serious problem happened deeper because of that.
I connected it to the bluetooth speakers and I was unable to start any music. And the phone is still acting crazy and overheats when I try to play anything.
Yes, but I rather meant that if its solely the jacks fault or is it possible that something more is fried. I googled a little bit and this kind of problem is accompanied with the damaging of the logic board. So I would not be able to fix it by my self I dont have the right tools, but it is even worth it to pay for the repair from professional?
The Nexus 5X, like other LG phones of that era, was somewhat notorious for motherboard failures, so the accidental plugging in could've been coincidental.
You would need tools if you don't have them, then locate parts , try get a quote from local phone repair center see if its worth it
RangelS25
