- Dec 20, 2011
- 464
- 27
- 0
Oh my my my..What has HTC done?
.. So I currently own the GS6 Edge, M8 and M9 and i've compared batter temp of each handset under the same conditions using GSM battery application. The results are very noticeable as the M9 is always 6 degress or so higher. For example, while each phone was on wifi,off the charger and no applications running the results were:
M9 - 76
M8 - 69
Edge - 71
I've order both devices because i'm trying to figure out which phone i'm going to keep for my second line. With the Edge, its software is very Samsung with all of the stutters, redraws, etc and the only wrong with the M9 right now is the battery drain seemingly due to heat.
Right now, both of these flagships suck, I just can't understand why these companies can't get things right..smh
Since HTC already put out an update I wonder if the issue with the Snapdragon 810 can be resolved?
By the way: Build quality on the HTC is much better than Edge..
M9 - 76
M8 - 69
Edge - 71
