photon needs to be restarted because it randomly does not work
stu5797
102
22
It randomly does not make/ receive phone calls. I have had to restart 2x to get it working. I wonder if it has some thing to do with Bluetooth being on. Very frustrating. Anyone else have this problem
Yes, happened to me once. Haven't had the problem since. Are you using google voice? I thought it might be something with that.
Sent from my MB855 using Tapatalk
Re: photon needs to be restarted because it randomly does not wor
Yes I am using Google voice. This is a horrible flaw and I hope it can be fixed. I am worried I have to return the phone. What r ur thoughts
Just keeping an eye on it for now. I had an EPIC replaced because it couldn't make phone calls for six hours. I went to find out the next day that Google Voice had crapped out, so my replacement was for naught. If it happens again (someone else mentioned it in another thread), I'll return the unit. I've alerted Motorola Tech Support, so hopefully they will look into it.
Thanks so much. Can u please keep me in the loop either here or in a pm. I am worried I will need to get another devicce
I don't use Google Voice, and I've had to pull the battery twice because of this problem. I'm a little disappointed.
It just happens. Just try making a phone call every hour and u may run into it
Do you still have your old phone powered on? Seems to be causing some issues.
Yes I have my old phone powerd on that is a great point I will turn it off now thanks for the idea and I hope that works
Mine's been powered off since yesterday, so that can't be it.
Are any of you using an Airave? Have had major issues with this bug. Power cycling and battery pulls help but only temporarily. Sprint is sending me a replacement but I'm concerned!
I am using Google Voice with Sprint Integration and an Airave but when I was out running errangs yesterday calls were flawless. When I got home again the problems started back up. Today audio was completely out until I power cycled the phone.
Not good Sprint and Motorola. You would think that pre-release testing would've caught this bug. While talking to Sprint level 2 support last night they said this audio bug was a known issue and that a software update in mid-August was supposed to address this issue.
Best of luck to those of you who rely on this as your business phone or only phone. I did try to get the level 2 support specialist to give me some identifying information on the bulletin so I could reference it here but he said there was no identifying support bulletin #.
Are any of you using an Airave?.
I am using and airave and when dialing *99 it tells me that the feature code is not available and if i remember correctly my Nexus would say that you are using an airave if you would dial that.
I also have an airrave. This is crazy and its my business phone
This is the main reason why they say to make sure the old phone is shut off. I've done this myself; new/old phone on and while the new one appears to be working fine, the old one is trying to provision (which it shouldn't).
I purchased a Photon today and it is difficult to keep it running. If I leave the phone sitting for 20 minutes or more I have to remove and reinstall the battery to get it going again. I do not use Google Voice. Very disappointed. Spent a half hour with Sprint and did a hard reset. The tech rep suggested I replace the phone tomorrow. I forgot to mention the random soft resets the phone does when I am trying to keep it awake. The Photon makes the Palm Pre that I replaced look pretty attractive right now.
yep having this issue too and i am very worried
very very worried
i think it may not hardware related.
My co-worker is also having this issue. He also has a 4G bug where it constantly tries to switch networks forcing reboot. I have a feeling the phone may not last long before he switches to something else...
Sent from my SCH-I510 using Tapatalk
Had to reboot ... again due to this issue
kiki2025
