Pie Beta is Live in US for T-Mobile and Sprint ONLY
Tried to enable the Midnight Blue ICONS but does not seem to work...anyone else finding this?
How long did it take for the update to come threw after you registered Iam on sprint did the registration and still havent got the update yet
I'm on Sprint. I got the beta on day1 once available. I was looking for it once I knew it went live in Korea. My Samsung + app got an update. I clicked register, and then a few minutes later I checked phone for updates and there it was.
riccowboy2014 is correct...
What threw me off in the beginning was the steps...
You first must update the actual Samsung+ App...then scroll to the bottom of the App and register for the beta...you will see a message that says "it may take a few minutes"....after that I received the update through the normal process of Settings..Software Updates....etc...
Thanks for all your help...one other question as you seem to be quite ahead of me...the Badges that appear on the app Icons like e-Mail and Text Messages to let you know you have a new message are gone now and I have still selected that they appear but so nothing ...am I missing something ?
I can change my icons in the Galaxy apps themes. Had to restart phone after I applied the new icon.
What version of the Samsung + app are you Sprint users using? I don't see anywhere to register for the beta.
Checkpoint: 3 days into the beta and so far most of the small bugs I had on it were gone after several cache partition clears and restarts. I still reported it Samsung just in case they're not officially gone, and i encourage everyone to report any issue you have to them through the Members app, so that they can get taken care of. Only issue I still have is the battery life went down by an hour or 2, other than that I'm loving Pie, and it's just the beta!
so maybe someone could help me understand this-- I have a Samsung Galaxy S9 plus with T-Mobile I registered it on the Samsung+ app, I've cleared the data, logged in and nowhere within the app shows any beta availability for download--even going to settings update and manually download produces nothing--help appreciate it
Go to the Samsung+ in the app store where you typically install uninstall. Scroll down and select beta permissions for the Samsung+ app. Then you will see the Samsung+app update needed. After that go in the app do the setup and login. then you should see the beta registration.
off8485
